Question about Dometic Rooftop RV Air Conditioner
Is there a switch assy made that the a/c fan turns off when the compressor shuts off
    Genius:
  • Dometic Master
  • 1,363 Answers
It should turn off in the auto position of the thermostat
Posted on Aug 17, 2015
If compressor comes on & cuts off soon after, is it bad or what do i check before replacing parts or fridge?
Does not sound good. The compressor gets turned on my the thermostat and off by same when temp is reached. If the compressor is drawing too much power the clixon will shut down the compressor and turn it back on when it cools. And it will keep turning on and off as it heats up and cools.
The only way a compressor can draw too much power is if the system is overcharged OR if some of the windings have shorted out , the resistance of the motor is less, and more current is flowing thru the remaining good windings.
If you have an ammeter handy you can check the current draw against what it is supposed to be. Expect the worst..
Aug 30, 2015 | Refrigerators
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
Why would my air conditioning in my Mitsubishi eclipse cool on #1 setting but kick off on any other setting above #1?
When you say "kick off," do you mean that the fan shuts off, or that the compressor cuts off? (Unclear.)
If the fan is shutting off, check your fan control switch, blower resistor, and blower motor.
If the compressor is cutting off, check your refrigerant level, and the compressor cycling switch.
Jul 25, 2014 | Cars & Trucks
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
LG Air Conditioner LST182V-4
It may cause it to shut down if it's a safety thing, but it sounds like the compressor's faulty to me.
May 16, 2012 | LG Heating & Cooling
A/c works great when fan is on high speed when
Could be as easy as a new blower motor switch or blower motor resistors.
Apr 16, 2010 | 1995 Nissan Pickup
Compressor/fan not shutting off
If this is a window air unit, it is probably the selector switch. If this is an electronically controlled unit, I don't have a clue.
Jul 08, 2008 | Kenmore 72056 Air Conditioner
Condenser fan inop
genarrly the fan motor runs in conjunction with the compressor assy, ifhte compressors not runnig you wont get hte fan to run either. is the compressor running??? if so check the wiring between the 2 components
Mar 23, 2008 | Refrigerators
Freezer
chances are you have a bead compressor, you can try to replace the starting device (overload relay assy). mounted to side of the compressor, usually about 50-100 bucks. sometimes it works sometimes nada!! and for how long it will work no one can tell. check you manual and see when oyu purchased, most refrigs came with 5 year coverage on compressor assy, costly repair w/o warr
Mar 12, 2008 | Refrigerators
BLOWER FAN WONT SHUT OFF WHEN THERMOSTATE IS OFF
The compressor coming on when the contact is pushed is o.k. they all do that. As for the blower fan not shutting off, some brands (Payne for example) the heating fan relay is a n.c. (normally closed ) relay. so if the time delay relay or thermal link are bad or not connected, the fan will blow even when it is turned off.
Aug 19, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
