Question about Samsung DVD-V4600 DVD Player/VCR
Dvd-v4600/tray will not open - Samsung DVD-V4600 DVD Player/VCR
Dvd plays but will not eject. Screen says open but then goes to play.
Well first of all you may try the following steps-
Unplug the power cord from the electrical outlet for 30 seconds.
Plug the power cord back into the electrical outlet.
Attempt to open the disc tray.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the above steps do not works then there may be some mechanical problem in the tray. Please post further comments if the above steps not worked.....
Good Luck!!
Thanks for using FixYa!!
Mar 27, 2011 | Samsung DVD-V4600 DVD Player/VCR
How do I manually remove a dvd from a samsung dvd-4600
just opened the cover find the tray and turn the gear to eject the disc.
Jun 20, 2010 | Samsung DVD-V4600 DVD Player/VCR
Samsung V4600
replace the loading and the belt
Oct 10, 2008 | Samsung DVD-V4600 DVD Player/VCR
Stuck DVD
To solve this problem, I unplugged the power cord then use a knife to open the DVD door from the top down. On the left side under the DVD tray is a small white gear. Use a knife or small screw driver and turn the gear toward the right (counter clockwise). The tray will start to open. You should be able to pull the tray out and remove the disk.
Sep 14, 2008 | Samsung DVD-V4600 DVD Player/VCR
Dvd 4600
DVD tray will not open, the display comes up poen but the tray doesn't come out.
Jul 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
How i unlock the codes???
1 - Select DVD mode
2 - Make sure there is no media on the tray
3 - Turn the DVD off using the remote control
4 - Turn the DVD on using the remote control
5 - Press "subtitle" key
6 - Press 7688478 on the remote control
7 - Press and hold 9 on the remote control for some time
8 - Open the tray
9 - Close the tray
10 - The DVD-V4600M is now region-free
If it doen't work at first turn dvd player totally off and try again and hold 9 for longer.
Mar 27, 2008 | Samsung DVD-V4600 DVD Player/VCR
Record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Mar 26, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
Jerry Greenberg
Jerry Greenberg
