Question about Maytag MEDC200XW Centennial Electric Dryer - Commercial Grade - White
Timer not advancing and not heating up - Maytag MEDC200XW Centennial Electric Dryer - Commercial Grade - White
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
Dryer doesn't heat and runs constantly
depending on the model; if the timer is in the automatic cycle it will not advance if there is no heat, it must heat in order to satisfy a thermostat to tell the timer to advance this is what makes it automatic. If the timer gets to the end of the timed cycle and will not advance to off, sounds like a bad resistor connected to the timer, I would first check the heat circuit to find out why its not heating. Dont mean to complicate, but everything in the dryer has something to do with heating, element,thermostats, temp switch, timer and even the motor. Check for burnt wires at the terminal block for the cord. hope this helps.....
Nov 19, 2008 | Dryers
Maytag MEDC200XW Centennial Electric Dryer - Commercial Grade - White Logo
15 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
