Question about Garden
Briggs&stratton snow thrower model 536.881510
The thrower bogs down and dies out after auger touches the snow
  • 2,027 Answers
Sounds like a belt that is worn out or needs adjusting to tighten it up.
Posted on Jan 27, 2015
3 Suggested Answers
  • 451 Answers
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Posted on Jan 01, 2014
SOURCE: How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Posted on Feb 09, 2014
Replaced a broken auger control cable on my 536.881400 snow thrower, but now the auger engage lever cannot be fully pulled back.
possible that is the problem
see if you can move the end of the cable closer down the handle (control lever) to give it enough length
check how you fitted the cable and the spring may fit in a hole on the other side of where you put the cable end
Nov 29, 2016 | Garden
Oil & what base weight
30 weight oil only unless its two cycle then use lawn boy oil
Sep 17, 2014 | Garden
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Can't get snow thrower to start
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
