Question about StrandWare TEKLYNX LABEL MATRIX, V7, 5 USER (LM75) for PC
Strandware label matrix 5.0. - StrandWare TEKLYNX LABEL MATRIX, V7, 5 USER (LM75) for PC
My dot matrix printer won't stop printing when it runs out of labels
Sounds like the media detect sensor is jammed or broken. Remove the platen and check underneath to make sure a label has become stuck over the sensor which would trick the printer into thinking it always has media.
Oct 17, 2014 | OKI MICROLINE 320 Turbo Matrix Printer
How to enter matrix to the calculator
Turn calculator ON
Press the Mode key.
Select the Matrix Option
Select the name of the Matrix: MatA , MatB, or MatC
Choose the dimensions of the matrix (3X3, 3X2, ..2X1)
Calculator displays a template (empty spaces where you enter the matrix coefficients.
Type = after each element.
Press AC to exit the matrix editor.
Now you are ready to do (legal) operation on the matrix.
Available opeartions are found under SHIFT 4: Matrix.
To enter a matrix label on the command line (MatA, MatB, or MatC) you press SHIFT;4 (MATRIX), and select the label by pressing the relevant number in the list of options
Jan 24, 2012 | Casio FX-115ES Scientific Calculator
How to enter the matrix
Open the ScratchPad/calculator application then press MENU.
Use arrows to highlight Matrix/Vector or just press 7
Press 1 Create then 1:Matrix
Choose/Enter the dimensions.
Highlight the OK button and press ENTER. The screen displays a template of your matrix.
Enter matrix coefficients.
If you plan on doing something with the matrix, you have to give it a label (name).
Aug 28, 2011 | Texas Instruments TI-Nspire Graphic...
105SL is taking template from Label Matrix and stretches it so the data matrix part is unreadable when scanned. How do I make it take an existing template and retain the print size, font and 2D?
Check to make sure you have a 105SL printer driver. Also check to see if you have chosen ZPL for the language as well as the proper resolution (203, 300 and 600 dpi).
Sep 28, 2010 | Zebra 105SL Thermal Label Printer
Need a Strandware (not Windows) driver for a TEC
bartender ultra light + driver or use a tecb472 driver (same resolution same language
Feb 24, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
I am printing individual labels and want the stop after printing the label - goes down 4 or 5 labels
You have to go into your printer settings and change the size of the "paper" you are printing to so that it matches the size of the labels you are printing to.
Jul 15, 2009 | Panasonic KX-P2023 Matrix Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Solving matrix
Go to your matrix button and enter a "3x4" matrix.
Then enter it as follows:
-3 4 5 7
4 3 2 9
-5 5 3 -10
Then exit out and go to "2nd->matrix->math->rref(". Then press enter.
Your screen should look like this:
rref(
Then go to matrix and select your 3x4 matrix, press enter and close it with a parathesis. Your screen should look like this:
rref([A])
Press enter and the screen should say this:
1 0 0 2
0 1 0 -3
0 0 1 5
So,
x=3
y=-3
z=5
Hope this cleared up the confusion!
SJ_Sharks
Mar 03, 2009 | Texas Instruments TI-84 Plus Calculator
Label printed too long
¿Que software de diseño estas utilizando (label matrix, codesoft, bartender) ? Estos programas tienen sus propios drivers, pero cuando utilizas otro driver puede haber conflictos con los tamaños de las etiquetas. Verifica que las dimensiones de la etiqueta en el driver y en el programa sean los mismos y que los margenes sean los correctos. What design software are using (label matrix, Codesoft, bartender)? These programs have their own drivers, but when you use another driver may have conflicts with the size of the labels. Verify that the dimensions of the label on the driver and the program are the same and that the margins are correct.
Jan 19, 2009 | Datamax I-4208 Thermal Label Printer
StrandWare TEKLYNX LABEL MATRIX, V7, 5 USER (LM75) for PC Logo
Top StrandWare Computers & Internet Experts
David Payne
David Payne
Are you a StrandWare Computer and Internet Expert? Answer questions, earn points and help others
