Question about Teac Audio Players & Recorders
Looking for the sony part number for the laser pickup for the adcom gcd-600
SOURCE: adcom gcd-600 won't play
If I understand your issue, you press play and the player does not recognize the disc, the optical pickup may be defective. I suggest you contact an Authorized Adcom Service Center. For further questions, contact Adcom directly.
Posted on Jan 08, 2008
  • 77 Answers
SOURCE: Laser pickup assembly
you should look on ebay they might have it there.
Posted on Feb 11, 2008
SOURCE: Adcom GCD 700
Dan, in this case the sticker has been removed (or was necer there in the first place) . Unusual.
thanks for your post and will try a KSS 240.
Good machine and I am looking foward to spinning discs with it again.
cheers,
Posted on Apr 02, 2008
petraman7
  • 1175 Answers
SOURCE: Disk intialization/read
It will require a tech to open and clean the laser lens and change the drawer belt.
Posted on Apr 01, 2009
  • 718 Answers
SOURCE: Need manual for both Adcom CD players I own GCD-750 and GCD-575
For the owner's manual for this legacy(old) unit go to;
http://www.adcom.com/data/manuals/gcd_750manual.pdf
For $350 you should be able to buy 5 new units- at least.
Posted on Apr 02, 2009
Adcom GCD-575: This unit has been the best performing player I've ever owned. After 15 years there is a problem. After insertion of a disc there is a spin up of the CD but no data is reflected/read within...
Your laser mechanism has lost its ability to focus on the surface of the disk and can no longer read the data. Needs to be replaced since repair not cost effective.
Jul 04, 2017 | Adcom Audio Players & Recorders
GCD-700 does not turn on. Internal fuses OK
If the fuse is intact the fault must be checked from the power supply to the main motherboard section.
Check if the power supply works, if not check the SM drivers .Click the link below;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 17, 2011 | Adcom GCD-700 5-Disc CD Changer
Adcom tv tuner driver of multimedia controller
A driver can be downloaded from DriverGuide.com
http://members.driverguide.com/driver/detail.php?driverid=1281766&action=download
Also Supports: AD-TV878R - ADCOM TV/CAPTURE -, Bt848 Video Capture Device, Bt849 Video Capture Device BtTuner, Temic WDM TvTuner, BtTuner, Philips WDM TvTuner (PAL BG), BtTuner, Alps WDM TvTuner, BtXBar, WDM Crossbar, BtCap, WDM Video Capture, Bt878 Fusion Capture Device - Video Section, BtTuner, Philips WDM TvTuner (PAL I) Manufactured By: Other Companies, Brooktree Corporation, Conexant, Brooktree File Name: PCTV.rar (6.5 MB) -------------
If required register for free donload, driver is available on that forum
Kind regards
Jul 21, 2010 | Adcom GCD-750 CD Player
I need to replace the laser assembly on a ADCOM GCD-750
I thought it used a KSS-240 which is a Sony laser.
# will be on the laser and Mcm has it for I think $35
Apr 16, 2010 | Adcom GCD-750 CD Player
Apr 02, 2009 | Adcom GCD-750 CD Player
Mar 31, 2009 | Adcom Audio Players & Recorders
Adcom GCD 700 tracking problems
Hi mate,
I experienced this problem awhile back with mine. I had it serviced and the techs couldn't find anything wrong. They cleaned the laser and lubed the tray and sent it back. To my dismay, the problem re-started shortly after arrival and then stopped. By coincidence, I had just finished a home theater set up "that did not have wall to wall carpeting" and low behold the problem stopped and never re-surfaced. I summed it up to static charge/discharge which might also be your problem.
I hope that helps.
Jun 05, 2008 | Adcom GCD-700 5-Disc CD Changer
Adcom GCD 700
Is there a specific question or just generalities? Open up the top and the Sony optics number should be right on the optic assembly. I believe that it uses a KSS-240 optics assembly. What else do you need?
Dan
Mar 30, 2008 | Adcom GCD-700 5-Disc CD Changer
Adcom gcd-600 won't play
Dec 02, 2007 | Adcom GCD-700 5-Disc CD Changer
ADCOM GCD700 5 disc CD player
Are you sure the fuses located on a PCB below the opened drawer are all OK? Otherwise you likely have a mechanical issues and I suggest you contact an Authorized Adcom Service Center. For further information visit www.adcom.com and contact Adcom. Affiliated Electronics in Hillsborough, NJ, may be your best bet as they have salvage Adcom parts.
Nov 12, 2007 | Adcom GCD-700 5-Disc CD Changer
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
