Question about Dishwashers
Keypad not working on ken more 655.1277
There is power going to the unit, but lights do not work
My unit has been working for two years , however it started up fine yesterday, but today it locked up on the Lowrance elite hdi screen it would not power down, I had to pull the power.
Hey Ken, My unit did this same thing.. I unplugged all the connections, replugged them and it has worked fine ever since??? ..just my personal experience...
Feb 21, 2016 | Lowrance Boating
GE microwave oven not working
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE SpaceMaker Microwave Ovens
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not open
try pulling emergency rope open door and close it this may reset opener if you have electric eyes make sure they are clear and they line up
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool range problem
If you where to touch bake, does the unit turn on? Or is the keypad none responsive? I would say if the keypad is non responsive you have a bad keypad. Can you check the connection and see what happens after you unnplug the connector and reattac. Does the lights light back up? Do you have a Display? If the Display is not working could be a possible bad controller.
Jan 06, 2009 | Whirlpool Kitchen Ranges
Speedometer, check engine, hazara and tcs lights stay on,
It ken be many problems,bad contact ,clamping force,tcs/abs unit.
The best you ken do is conect the TECH2 to check def.codes!
Dec 20, 2008 | 2001 Saab 9-3
I cANT ON MY PLAYER
when you reset it and turn it on try waiting a bit.
then look and see if the unit looks like it's got a light on.
if it does hold the power button until it powers on.
then try holding the power button until you see goodbye to turn off the unit.
if that doesn't work when you turn it off and the keypad light is still on then reset it again.
hopefully that works..... good luck
May 25, 2008 | Coby MP-C7085 MP3 Player
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
