Question about Yard Machines 305cc 30-in Two-Stage Gas Snow Blower 31AH6ZFH500
Chute wanders Directional responds to crank but during use it swings to one side on its own
  • Yard Machines Master
  • 2,392 Answers
Sounds like the part that spins the auger is either broken or worn out. Check and see if the bolts are loose . Mine a piece of the plastic that holds every thing in place fell out and I hand made and fastened one in or you can go to a small engine place that sells blowers and order a part. You may have to let him see what is needed.
Posted on Jan 27, 2015
The crank won't turn the chute, the plastic teeth has a gap from the crank about an 1/8". First time I used the machine was this past weekend's storm. Brand new machine bought in September.
Make sure the Chute is sitting down on it's mount properly. Sounds like either some hardware shook lose and cause the Chute to lift or many of these newer machines are all plastic and parts break easily in that chute mounting area
Jan 25, 2016 | Garden
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
Life fitness ticking from foot pedal
1Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Version:1.0 StartHTML:0000000168 EndHTML:0000002129 StartFragment:0000000818 EndFragment:0000002112
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
God bless you
Mar 31, 2013 | Life Fitness X8 Advanced Elliptical Cross...
Have a mtd snowblower the chute wont turn its stuck pointing to left the crank turns but will not turn the chute i tried cleaning the snow and ice from around it like its frozen
Where the crank shaft meet the chute there is a connection which is held in place bt a cotter pin or (on some models) a small screw. These can loosen and fall off causing the chute to stay in one position when the the handle is turned. Re-attach the shaft to the chute with a cotter pin or screw.
Feb 19, 2010 | Plumbing
The dryer is making a noise that sounds like baseball cards on a bycycle wheel! What is causing this noise?
you may have something in your lint chute. after removing the power take the venting off the back. reach in the hole and feel around if you can get your hand in there. if no you have to take out the lint screen. there is two screws under there take them out take the back panel off then go to the front top and carefully pry the front of the top up there is clips holding it down in front.swing it back against something like a wall and go to the back. to the left where the filter goes in there is four screws holding the lint chute on remove them and you can carefully swing it to the side. sometimes you need to remove the two screws holding the fusalage to the back. then check the blower area.some parts may be sharp so ware gloves. good luck!
Jan 15, 2010 | Kenmore 62602 Electric Dryer
How to install spring on Ariens chute
Not a DIY fix as took the snow blower into the shop for them to repair it.
Oct 20, 2009 | Ariens Garden
The pin that holds the mixer to the stand keep working it's way out when I mix dough.
Hi, Mixing Dough is tough. the neading hook really works hard and the pin will like to wander out on the left side of the mixer "right side if your facing the it". What I did was find an smaller elastic band and with the pin sticking out a 1/3 of an inch from the opposite side from which it wanders out.
loop the band on it as many times as possible so its stays on tight . with this you now have a bumper and as the pin vibrates to wander out the elastic bumper will gently keep pulling it back during the vibration cycle keeping it in check .
Works perfect but still inspect the pin and bumper before each use.
Mike
Aug 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Sony PS2 controller left side directional button inop
i know what you mean try pulling the button and then on the game on menu change the controll or buy a new one in game stop for $15.00
Mar 13, 2009 | Sony PlayStation 2 (PS2) Console
LG VX8300 - Keeps dialing last number called
Yes. on the side of the phone there's a voice command button .. with a twist ... it'll respond to voice command but it'll also respond to the directional buttons and sometimes .. the volume buttons work as directional buttons as well.
Dec 20, 2007 | LG VX8300 Cellular Phone
Yard Machines 305cc 30-in Two-Stage Gas Snow Blower 31AH6ZFH500 Logo
91 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
