Question about Salter Stainless Steel Electronic Bathroom Scale
INTERMITTANT READINGS How to fixBathroom Scales
Digital scales weigh half of accurate weight
Recalibrate. If that does not take, then there is an issue with the scale. Try installing a new battery since a bad or weak one often results in erroneous readings.
Jun 28, 2017 | Health & Beauty
My scale reads full when i turn it on whats wrong
Most scales will have what is called the "TARE" button... push the "TARE" button when nothing is on the scale and it should 'zero-out.'
Once it is zeroed, it should give honest weight readings.
May 13, 2016 | Health & Beauty
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
Aug 26, 2013 | Health & Beauty
This is a new scale. Every time you get on it a new reading?
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
Aug 15, 2010 | Conair Large Digital Display Memory...
How can change the lb to kg scale
how do I get the scales to read in pounds?
Dec 07, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Fat reading accuracy problem
You must not be dehydrated - do not use first thing in the morning or immediately after a workout or after consuming alcohol. Use 3 hours after a meal and after voiding your bladder. Women may experience fluctuations with retaining water, and those on diuretics may see inaccurate readings. You need to weigh yourself without clothes.
Aug 27, 2008 | Detecto 6475 Digital Chair Scale, 400 Lb...
Salter Stainless Steel Electronic Bathroom Scale Logo
24 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
solver2010
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
