Question about Brother ULT2003D Disney Sewing & Embroidery Machine
Handwheel frozen on a brother ult2003D after needle broke
3 Suggested Answers
  • 1116 Answers
SOURCE: I have the Brother ULT2003D the part that holds
Contact your local Brother dealer and ask the OWNER if the service tech can get one of these for you.
You should be able to pick it up without taking the machine in.
Posted on Mar 01, 2010
  • 1564 Answers
SOURCE: My Handwheel on Brother LX
sounds like you have the bobbin clutch disengaged. Check to make sure you have flipped it back to sewing mode.
Posted on Mar 08, 2011
Sewing machine hand wheel stops needle when it should be working and vice versa
Hi, the link below is a youtube instruction video for a brother sewing maching, Also there's other brother video's you can click on down the right side of page..... I hope this helps...........CHEERS..
Brother Sewing Machine Instruction Video
Apr 03, 2016 | Brother Sewing Machines
Brother ULT2003D Plz say filter over screen can b replaced.Any idea on cost. Not sure if mom wiped with solvent but resp 2 touch, just can't see. Thanx 4 any help. Repair agt tryng sell me a new one.
the only suggestion I have is go or call a sewing machine shop that works on brother sewing machines and ask them about the screen,, and what it would cost to replace it, and that will help you decide if you want the repair cost or to trade it in on a new one,, BUT DON'T CALL THE ONE THAT WANT'S TO SELL YOU A NEW ONE...
Jun 06, 2015 | Brother ULT2003D Disney Sewing &...
On my brother ult2003d I can't get it to sew two stitches before it bird nests appear under the needle. changed needle, threads, blew it out, nothing seems to help. flashes up on screen that safety device...
try these suggestions first
make sure top thread has not come off thread take up lever
try a new needle--make sure it's the right one for the fabric being sewed--make sure the needle is inserted correctly up into the needle holder
make sure the bobbin is turned the correct way in the bobbin case
if none of these suggestions help
it's possible that the timing could be off, it would be a good idea to have the machine checked
Oct 23, 2013 | Brother Sewing Machines
How do I get my handwheel to work on my singer 2277 sewing machine the needle broke and the the handwheel won;t move
when the needle broke, it could have damaged some part in the machine and also the machine could have jumped time,, having the machine checked would be a good idea..
Sep 17, 2013 | Sewing Machines
Brother pacesetter ULT2003D
try using a different spool of thead on the top and bobbin
also try changing the needle
and if these suggestions don't help then call the repair shop and check
with them about the machine not sewing light fabric
Jan 04, 2013 | Brother PE770 Computerized Sewing Machine
The motor on my huskystar 207 has seized up.
Needle broke then it seized? Could be any number of things from a bent upper arm to a motor that needs servicing. I recommend you take it in for professional repair.
Sep 15, 2012 | Husqvarna Huskystar 207 Sewing Machine
Brother pe770 - needle threader is stuck in the down position while trying to thread it
Hi Kay,
I found the manual, in case you don't have one, HERE. On page 30, it has an illustration showing two buttons, and the presser foot lever. If you press the button once or twice, it will raise the needle.
> Press (Needle position button) once or twice to raise the needle.
> The needle is correctly raised when the mark on the handwheel is at the top, as shown below. Check the handwheel and, if this mark is not at this position, press (Needle position button) until it is.
Get the manual if you don't have one, that will give you so much more than any here can do, but I think that should solve you trouble, Please rate and comment, Thank You,
Joe
Sep 17, 2011 | Brother PE770 Computerized Sewing Machine
I have the Brother ULT2003D the part that holds the needle broke. When I tryed tightening the screw to holed the needle the part where the screw goes in broke. Where can I get a replacement?
Mar 01, 2010 | Brother Sewing Machines
Handwheel won't turn, take-up lever not accessable
Make sure the bobbin winding settings are "in-active" - this could be the position of the pin for the bobbin or the center knob on the handwheel, depending on the model you have.
Open the throat plate and bobbin case to be sure there aren't any threads tangled there. This can stop the handwheel from turning.
Feb 23, 2010 | Brother Sewing Machines
Belts intact, press on pedal, motion in belts, but not on needle end
does the needle go up and down when you turn the handwheel by hand? if so, one of the belts may be slipping - tighten it enough to make it grab.
if the handwheel does not make the needle go up and down, is the handwheel lock for bobbin winding un-locked? if so tighten the handwheel lock inside the handwheel. if the handwheel lock is tightened and the handwheel spins when motor runs the handwheel lock is asembled incorrectly. if this is the case, undo screw in handwhhel lock nut and spin lock nut off machine, then remove pronged washer and turn 1/3 turn and re-install.
scott
Jul 23, 2009 | Brother LS-1217 Mechanical Sewing Machine
Brother ULT2003D Disney Sewing & Embroidery Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
