Question about Frigidaire GLWS1233A Top Load Washer
My front loader move only one way - Frigidaire GLWS1233A Top Load Washer
How to block the tub for moving across country?
front loader or top loader
need to get between the drum and washing machine inner casing
polly styreyn.. rags .lots of bubble wrap thick cardboard
Apr 01, 2017 | Washing Machines
My machine is spinning really loudly and moving from its original spot. Is it out of balance. How do I fix it. It's used daily.
you forgot to mention if it is top loader or front loader
if top loader check the 4 suspension rods that hold the tub up are intact
if one is longer than the others then it will always be out of balance
call a technician for a proper diagnosis
Jul 13, 2016 | Washing Machines
Front loader won't start on certain cycles
Hello sidneyskiss - From what you have described if only the normal cycle is working, then there seems to be a communication problem coming from the main control board or wiring failure. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart washer. If it proves to be ineffective, I would suggest contacting a professional technician to move forward accurately.
Jan 08, 2013 | Frigidaire GLTF2940ES Front Load Washer
I have a broken bra wire stuck behind drum of LG turbo drum washing machine, how do I get the drum out??
You don't say if it's a front or top loader. I managed to get one out with a strong magnet inside the drum just moving it about until it appeared near one of the holes in the drum without taking the machine apart. But it was a front loader and is probably easier than a top loader.
Jan 26, 2012 | Washing Machines
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Front loader moves to much. I already balance in place it but it still moves to much.
ajust the legs on the bottom of the machine see if this works if not write back
Jul 03, 2010 | Frigidaire ATF6000ES Front Load Washer
We are moving do we need to do anything special with the front loaders before moving.
it is recommend you put the shipping bolts that came with the unit back in. ideally you dont want the tub to be bounced around
Jun 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
Frigidaire GLWS1233A Top Load Washer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
