Question about Canon IMAGERUNNER 3530 Copier
How to do a developer stir - Canon IMAGERUNNER 3530 Copier
Floor came out glossy
Did you stir well? The flattening agent will settle in the bottom of your paint container and must be stirred for approx 5 min before using. If you did this, then the flattening agent was apparently left out during the manufacturing process
Dec 13, 2013 | Minwax 1 Gallon High Build Polyurehtane...
Code cof32 appears
cof32 is telling us that ATDC sensor is reading toner supply incorrectly, now this Toner Density Control sensor sits inside the developer unit of this machine, and toner is feed into it, where the atdc sensor reads the amount of toner that it has mixed with the developer and adjust it occording to level initally set when developer was first installed.
Developer can become old and not attract the toner any more
Toner can clog up and not be able to get to it
Developer can be spilt so it is no longer at right level.
Maybe it wont stir cause of something mechanical
Sensor rarely fails
or maybe the ATDC sensor needs to reset it's level (service f8)
not sure but ...Service mode stop 00 stop 01 then select F and 8
link to new dev
http://supplydepot.com/amazing/itemdesc.asp?ic=MIN8936416&eq=&Tp
Nov 05, 2007 | Minolta Di152 Laser Printer
Why wont my Computer fan work?
just try using it where its at upside down or the opposite side your using now. should be the same stir, just backwards. Stir is stir right.
Apr 05, 2012 | Cell Phones
Hi my copier text f2 code and i chang tuner but not worked plz give any reset code
Replace the developing unit. Use SIM 25 - 1 to perform stirring. in quick successetion place 'clear' 'auto' 'clear' then 25 and copy key.
Aug 01, 2011 | Sharp AR-5320 Black and White Copier
Que significa el codigo f2-02 de una copiadora sharp ar-m25
me marca codigo f2-02 copiadora sharp AR M455N
ke puedo hacer sera que es le chip o el cartucho.
Oct 01, 2010 | Sharp AR-M257 Black and White Copier
Dell 2135cn black toner prints light grey
The way I resolved the issue is to go to the Printer... literally walk to it (not via Windows or a Driver), Select Menu button on printer->Setup->Admin->Maintenance->Clean Developer. This will clean each toner cartridge or PHD unit, or to stir the toner in a new toner cartridge. Then it started printing solid black again.
It took me hours to resolve this but I hope it helps someone else and spares them the pain.
Aug 13, 2010 | Dell 2135cn All-In-One Laser Printer
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
Solution for error code e020004
The toner concentration sensor is faulty.
The developer inside the developing assembly is not stirred properly.
The sensor is subjected to stray light (no cover, front cover open).
The photosensitive drum has deteriorated.
Apr 23, 2009 | Canon CLC 1150 Color Copier
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
16 people viewed this question
old marine
old marine
