Question about Sylvania Audio Players & Recorders
Alarm wont go off - Sylvania Audio Players & Recorders
How do I disarm the alarm system on my 1998 volkswagen?It wont start ,cranks but wont run..I changed the plugs still wont start,someone said could be in the alarm system to disarm it.
The alarm would cause the car not to crank, and the alarm horn would sound. You can try unlocking the car from the trunk lock to disarm the alarm. But crank and no start could be a bad ignition switch. Do the dashboard lights stay on or go out while the key is in the crank position? They should remain "on". Worn ignition switch could cause the car to crank but not start.
May 04, 2017 | Volkswagen Cars & Trucks
94 camry alarm would'nt stop i pulled a black wir next to the horn now car wont start
the wire from the horn is part of an imobiliser so it wont start replace wire it sounds like imobiliser battery or alarm pad if wont turn off
Oct 13, 2012 | Toyota Camry Cars & Trucks
2004 heritage classic alarm wont deactivate
Hi Clair, for more information about your question please visit the websites below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Jun 14, 2012 | Harley Davidson FLSTCI Heritage Softail...
2009 H-D Flhtc Electra alarm lights flash bike wont start
Hi Anonymous, you may need an alarm reset, for more information about your question please visit the websites below. Good luck and have nice day.
Apr 20, 2012 | 2009 Harley Davidson FLHTCU Ultra Classic...
My 1998 dodge intrepid wont start and the alarm wont shut off
Try "cycling the key in the passenger door lock. Turn it all the way to the right and all the way to the left.
Jul 16, 2010 | 1999 Dodge Intrepid
Car wont start after both alarms were removed
Try to remove the After Market alarm only. The other might be the FACTORY alarm. Might want to leave the factory one in the vehicle.
Mar 17, 2010 | 1997 Honda Civic
Disable alarm 1999 dodge intrepid
HOW DO I MANUALLY DISABLE THE ALARM FOR A 99 DODGE INTREPID
Jun 14, 2009 | 1999 Dodge Intrepid
Car wont start after the alarm is disabled
is the alarm factory or after market need to know. very important..
May 11, 2009 | 1992 Acura Vigor
Car alarm stopped working.. Car wont start
the jetta has a faulty alarm system from the factory i have been working on one in my shop. the alarm moddule is inside the dash behind the light switch and has a 10 pin connector and a 6 pin connector. this can be bypassed if you disconnect both connectors and jump the two large wire on the 6 pin connectors, these wires operate your starter. the car will start and run but your alarm will no longer be active. the door locks and everthing else will still work. the only issue i am having is the factory radio isn't working because it is controlled by the alarm. but worse case scenario i can use an aftermarket radio if need be.
Feb 20, 2009 | 1994 Volkswagen Jetta
1998 cad alarm no start
Your GM product has a safety alarm, it shuts down the radio , or locks it.
I send ours to a GM dealer to get it unlocked. They don't give those codes out.
Jan 15, 2009 | 1998 Cadillac DeVille
22 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
