Question about Toshiba 36A50 36" TV
There is a delay when I use guide or volume - Toshiba 36A50 36" TV
Suggest a good delay pedal to buy for guitar.
According to many musicians rating, top three best delay pedals are:
? Donner Yellow Fall Vintage Pure Analog Delay Guitar Effect Pedal
? Behringer Vintage Delay VD400
? TC Electronic Flashback Delay and Looper Guitar Delay Effect Pedal
All these delay pedals are best in different conditions, you can choose any of them.
Tho check their reviews, you can visit this link:
Best Volume Pedal Top 5 Best Volume Pedals Reviewed by Musical Study
Feb 22, 2017 | Cameras
Low volume, high pith squill
The schematic is here:http://www.vintagesynth.com/roland/xp60.php Take note though that the design was changed for the newer DD3. Here is a link to a forum with links to later DD3 service notes:http://music-electronics-forum.com/t15879/. Start checking transistors at the input. Check voltage readings on pins on the I.C.s to see if they match the supply voltage at IC10 . If you get voltage readings on pins that aren't supposed to have readings there is a good chance that the I.C. you are testing is shorted. Also check the diodes as you proceed.
Jul 26, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Sometimes volume won't stop going up when I press +/- control
try programmin the ir code with a delay. .3 .4 usually will solve your issue. part of trouble shooting when the remote is connected to the server theres an option to increase or delay the ir emitter. hope this helps
Jun 04, 2009 | Logitech Harmony 520 LCD Remote Control
Volume delay when used with iphone
Unfortunately, this is no correction for this, as bluetooth is still a pulse device, this delay is a communication problem and will not be corrected soon.
Apologies for our lacking in electronics. :(
Hope this helps.
May 07, 2009 | Motorola Mobility H700 Wireless Headset
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Mar 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Delay between the actual TV volume and the sound from the Speaker
The time delay is likely caused by taking the audio signal from the TV rather than the source. I would need to know more about the components in your system and how you have them currently connected to be of further assistance.
Feb 28, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Delay
if i understand it right, you recorded for example 2 tracks. recorded A then recorded B then you synced them together? if so, my bet would be adjusting the volume for each giving them balance. your master volume is your guide on this. hope this works.
Feb 06, 2009 | Steinberg Cubase SX3
Sound issue on LG 42LG50
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
Nov 29, 2008 | LG 42LG50 42 in. LCD HDTV
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Toshiba 36A50 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
