Question about Weiser Lock Powerbolt 1000 Lock
Will not lock when pressing lock button on keypad
Keypad works to unlock deadbolt but when trying to lock it does nothing - motor doesn't even turn - if I work the lock manually then push the lock button it sometimes works - also when I work it manually the key pad flashes
4 Suggested Answers
  • 15 Answers
SOURCE: Weiser keypad deadbolt lock deadbolt does not move
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Posted on May 14, 2011
  • 1015 Answers
SOURCE: we have recently installed this
As long as you can hear it trying to engage the lock I would say that you need to adjust the strike plate in the door frame for a more precise fit' You can use your key to lock the door and see if you feel any rough spots when it is engaging the strike plate.One easy way to tell where it is hitting if you can't see it is to use a magic marker and mark the strike plate. Try to close the lock with the keypad after the ink has dried. If it is hitting the strike plate it should leave a mark in the ink so you know which way you need to adjust the plate.. You can either move the entire strike plate or you can use a rat tail or round file to make it fit. If you have a dremel tool they work well with a metal circular file bit.Hope this helps you. Thanks.
Posted on Aug 17, 2011
  • 963 Answers
SOURCE: Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Posted on Aug 19, 2012
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Aug 18, 2012 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Our powerbolt does not work well in the cold. It appears as if the batteries no matter how fresh, are not strong enough to turn the bolt. I thought I had seen a new model where the keypad simply unlocked...
Batteries, when they are cold, do not give off the same amount of power. You can test this by putting them in a freezer for a few hours and then trying them in a battery operated device. They cold does not hurt them, and they will work fine once they warm up. Depending on how cold the batteries get for your deadbolt this could be the problem. Also if the deadbolt is rubbing at all against the lock plate it could put unnecessary pressure on the motor. Schlage does make a deadbolt system that uses a keypad and a manual turn. The Camelot or Plymouth models.
Dec 16, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Weiser Lock Powerbolt 1000 Lock Logo
50 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
