Question about AEG B4101-4 Electric Single Oven
Need to replace hinges on aeg B4100-M cooker door
How do you get the door off to replace hinges?
I have a Competence B 6139-4-m electric oven. the door does not close properly, have tried cleaning it as intruction manual suggests, the heat escaping from the oven has scorched my cupboards
the fault is unlikely to be the actual oven unit so therefore in order of least expense the things to check are:- the door seal being complete, the hinges not having been forced, the door not being buckled, self adhesive universal seals are available online from *spares etc. Hinges are easy to remove from the cooker and then can be unscrewed from the door and replaced. if it's the door I would have to say that's less likely to be available for a sensible price.
Feb 05, 2013 | AEG B1180-4 Electric Single Oven
Hi. Just need to know if the oven door is adjustable on our AEG double oven cooker? The bottom oven seems to 'leak' hot air slightly from the top right hand corner and when you press on the same point the...
Hi there is no adjustment. to fix it you will need to change both hinges on the door. Some models have a roller which may need changing (on the oven frame where the hinges are located)if the door is creaking when opened or closed. wherever you go for parts you wil need the model and product no from the oven located around the door area.
Jan 20, 2011 | Ovens
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Locked oven door to clean. Need instructions to
These might help you get the door off
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
Mar 04, 2010 | Ovens
My oven door won't open and its not locked or on clean. what do i do
Mar 03, 2010 | Ovens
Hinge snapped on Nardi EK95583AC Range cooker
I have the same problem and am about to replace both hinges and hinge runners (http://shop.ukwhitegoods.co.uk) recommend you should replace both hinges as if one is gone the other will follow soon. The section on the hinge gives a good account on how to replace the hinges safely and how to get to the runners that may need getting into the inside of the oven by removing the sides. I havent gone through this yet so cannot honestly give any more advice other than whats out on the web.
If you follow this link please:
http://tinyurl.com/djntxb
The parts you need are listed there for you. Part numbers 031118009907R and 031199009903R
Adamski
Apr 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
AEG B4101-4 Electric Single Oven Logo
24 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
