Question about Canon MVX20I Mini DV Digital Camcorder
Camer will not power on
Battery pack is new; camera has not been used for 4 years. Nothing happens when I put (charged) battery pack and turn on the camera
  • 67 Answers
If your battery does not seem to charge, then you need to carry out some tests on the device, the battery and the charger. First you insert the battery into another cam corder then you try to charge, if it charges, then it means the battery is okay and if it does not charge, then it means the battery is bad and need to be replaced.
Then i will advice you take the charger and try to charge another device to see if it will work, if it works, then it means the charger is alright but if it does not then it means the charger is bad and need to be replaced.
Finally, test the camcorder by plugging a well tested charger and battery into it and trying to charge it, if it does not charge then the problem is from the camcorder.
Posted on Feb 12, 2014
5 Suggested Answers
cpt100
  • 154 Answers
SOURCE: Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Posted on Mar 18, 2007
SOURCE: Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Posted on Dec 16, 2007
snickeldorf
SOURCE: No Power
maybe you have a p[roblem with your plug, if you see the orange light then it is charging
Posted on Jan 06, 2008
  • 8 Answers
SOURCE: Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Posted on Mar 05, 2013
Why won't my Powershot A495 take a photo?
iIt seems that the battery is low or not powerful enough to run the camera properly. when the camera notices there is not enough power it will automatically shut down. ensure the battery is fully charged up on the charger and then try it. the battery type is
Canon NB-3L and if the camera is a few years old or has been stored for a long time the battery may need to be replaced.
if all these have been done and still the problem persists i would recommend a dealer have a look at the camera.
to replace battery open slider plate on bottom of camera and flip tab to release the battery pack.
I hope this was useful.
May 28, 2014 | Canon PowerShot A495 Digital Camera
D80 will not turn on...battery fully charged
Do you get any numerals in the TOP LCD? Say a flashing ERR?
Or just no power and nothing works?
Jan 22, 2013 | Nikon D80 Digital Camera
Hey i just got my sony vx1000 and its not turning on. i put a battery in the camer and it turned on and mediately turned off and now the battery isnt coming out it or turn on. please help i dont know what...
Judging by the cameras response the battery may be low on charge. Try removing the battery (there usually is a button close to where the battery is inserted) and charging it overnight. If it still does not work the battery pack may be dead or worn out. You may need to get a new one as batteries gradually loose their capacity overtime and eventually die.
If the battery is a Ni-Cd or Ni-MH you can attempt to revive it by charging it fully, then discharging it by running the camera, and repeat this cycle many times.
Thanks for using FixYa,
Chartreuse
Jan 14, 2011 | Sony Handycam DCR-VX1000 Mini DV Digital...
Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
When I press the power button for my Olympus FE-190 to turn the camera on nothing happens. I haven't used it for a while so I initially thought that the battery might not have any charge. When I put the...
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
Feb 28, 2010 | Olympus FE-190 Digital Camera
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
NiCad battery not charging
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Oct 23, 2007 | Metz 60CT-1 Flash
Canon MVX20I Mini DV Digital Camcorder Logo
109 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
