Question about HP 2159M Monitor
White Screen When I turn on the monitor, it just displays a white screen. I can turn off the power with the power button but it wont display anything except a white screen. If i plug it into a computer it will turn black then white again. Any idea on how to fix it?
Garfunkel01
  • 56 Answers
SOURCE: HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Posted on Aug 15, 2007
SOURCE: computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Posted on Sep 06, 2008
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
  • 51 Answers
SOURCE: Monitor makes loud screeching vacuum sound; no screen display..?
check to make sure that there arent any magnets near or around it
Posted on Apr 13, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
WHY IS MY SCREEN STUCK ON WHITE?HOW DO I FIX IT?
move on to near by service center if u have valid warranty..
might b issue with the ROM OR DISPLAY problem..if its display, replace with the new one..if its ROM then they will flash and give u
Oct 17, 2017 | Cell Phones
My screen wont display
If you disconnect all the cables except the power cable, is the screen still white? White is unusual as it is the presence of all colors. Thus the white is probably coming from the video source.
If possible connect to a different video source.
Dec 09, 2013 | Samsung S22C150N 21.5" LED Monitor
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Plain White Screen on My Acer n35 PDA
Connect an external monitor to your laptop and see what it displays. The white screen is your backlight, you just do not receive any data. This could be because of a bad video card or a bad LVDS cable. Try the external monitor and let us know.
Nov 01, 2017 | Computers & Internet
All I get is a white screen
Is the power led button on while the screen of your monitor goes white and as it been displaying before?
If it as, have you check all connection to see if the VGA and all other connection are intact and well connected? if you have check all this, and yet, it is still white screen you get while the power button is on, it means your picture board is bad.
It means the picture board of your monitor has develop fault and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | HP w19 19" LCD Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Monitor displays white screen when connected and powered.
You've done sensible substitutions and it does sound like dead monitor.
The white screen is due to no pixels being controlled at all; what you are seeing is an unpolarized view of the backlight.
It's conceivable that a power supply problem is at fault in the display since it is unusual to lose all control over the screen as this has done.
The cause has to be common to all of the drive circuitry in the monitor and sounds like a job for a tech.
9 months? Is the warranty coverage known?
Unfortunately, warranties seem shorter all the time but it might be worth a shot to locate and email an inquiry to the manufacturer.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Apr 03, 2008 | Gateway FPD2275W LCD Monitor
Benq lcd Displays only white
Most often the all white screen is the result of a missing voltage to the LCD panel. We usually find an open fuse on the panel circuit board. Unfortunately replacing the fuse does not usually fix the problem.
Mike
Mar 02, 2008 | Computers & Internet
HP 2159M Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
