Question about Samsung SyncMaster S27B750V 27" Class LED Monitor
Noise problem I hate this monitor. This noise killing me.
Need to silence the low fuel "ding" sound.
put duct tap on the noise maker.
disable the dinger, but that kills other things...
the wiring page is 516 pages lone, 8w-30-31 page
The PCM brain, senses low level. and then sends a warning
to the Dash cluster brain, it then sets the low light
and the buzz.
(call dealer and ask for how to change programming...)
the fuel pump is fuel cooled
the pump is fuel lubricated.
it just hates sucking air (i promise) and self destructs.
so dont let it.
see 8w-40 sections
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Sep 25, 2013 | 1998 Jeep Cherokee
The monitor is half dark, constantly flickering, makes electrical/static noise that is coming from the back, controls have no effect
This sounds like a serious electric short in the internal workings of the monitor. I highly recommend unplugging the monitor from electric power and taking it to a business that can diagnose it properly.
I'd hate to say check the power cable and other diagnostics you do yourself because the risk of shock and injury is high.
If you have a Best Buy locally they tend to be nice about doing quick diagnostics on this type of thing for free, but they do generally charge for all work done.
Hope this helps!
Mar 13, 2011 | Acer X193W LCD Monitor
NOISE IN MONITOR
Hello
Something you can try is to have a look at the frequency of the monitor. Right click on the desktop, propperties and have a look at the settings.
It is usually the wrong frequency which result in a noise.
Hope this can be helpful.
Kind regards
Andrea
May 24, 2010 | HP W2007 LCD Monitor
SyncMaster 793DF 17" CRT Monitor: monitor makes high pitch noise...
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback.
Normally, it is the cause of the noise.
Warning: High Voltage!! Do at your own risk!!!!!!
Best regards,
May 16, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Monitor making noise and turning on and off
You may have bad caps that start outgassing due to caps failure, see example here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | ViewSonic VA1930WM LCD Monitor
My monitor is making a electronic noise
u have a problem with electornic circules
Nov 04, 2009 | ViewSonic VX2235wm LCD Monitor
Remove door chime for 99 malibu, or replace with light/flasher
This is my post. By the way, the car is dead now, I think the timing belt snapped at 95000mi.
Feb 25, 2009 | 1999 Chevrolet Malibu
Cpu fan noise problem
It appears that the 1GB RAM that you installed is generating more heat due to the density of the chips they require more power. This is what is causing the fan to work harder. To verify this you can re-install the original memory and see if the fan noise reduces due to lower heat.
Aug 08, 2008 | HP Pavilion dv6000z Notebook
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Samsung SyncMaster S27B750V 27" Class LED Monitor Logo
13 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
