Question about Sony Walkman D-E441 Personal CD Player
Sony cd display shows all eights
LCD display shows all eights
I have a Sony MHC-ZX70DVD unit, when turned on the display shows the radio working but ther is no audio output through to the speakers or headphones at all. Also the CD/DVD player woun't eject and all...
From Sony's Trouble Shooting site:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C154211&fes=true&mdl=MHCZX70DVD
If none of this helps, I suggest making sure your wires are correctly connected from your CD player to the speakers. Also, make sure no exposed wires are touching, it should make an audible hiss if they are touching anywhere.
If none of this helps, then I suggest taking it back to where you got it, may just be a dud.
Hope you get it working though,
Cheers.
Mar 09, 2011 | Sony MHC-ZX70DVD System
I have a Sony Bravia 52 inch HDTV that has a line down the middle of the picture in some shows, particularly when action is panning across a scene. Is this a common problem?
Check with a different CD or a different channel. Sometimes some,
secret codes are displayed to find the pirated CD. Any how check in different program channels. This is not TV problem.
If you have DVD try a similar action movies in CD and play to satisfy!
Aug 21, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Damaged LCD, Low battery LED on, wont comunicate with PC.
Replace or Repair the display on the Sony K800i. If your k800i screen is cracked, this guide will help you. If your Sony K800i LCD is dead, then this video will show you how to disassemble and replace it. If your lcd screen on your k800i is smashed, then this post will help you fix it yourself for a very low cost.
Replace LCD Screen on Sony K800i Display
Feb 06, 2010 | Sony Ericsson K800i Cellular Phone
My Sony Ericsson W580 just shows a white sceen an i cant go to anything else
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Mar 22, 2009 | Sony Ericsson w580i Cellular Phone
LCD not display
hello I've sony handy cam and I can't run the program picture package fro the cd
after I setup the it's dosn't found ,I searched for the program but I don't found it in free;
any body know how I can get the URL I was thank s.
thanks,,
Aug 22, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
No Display is coming on the Flip out LCD
CCD sensor seems faulty . Sony should repair free of charge but otherwise it is not an expensive repair to perform : requires 1 hour labout at most. ( the componenet itself is not expensive ).
Aug 28, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Lcd display
LCd may be defective. Takes 4 weeks to get from sony service. Pl.let me know after cleaning the LCD connector for proper contacts.
May 20, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
LCD Display
Something is wrong with the lens unit or the ccd imager. Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
Mar 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Walkman D-E441 Personal CD Player Logo
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
