Question about EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard
F panel connection cable - EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard
What does F 14 mean on electrolux stove?
f14 misconnected keyboard cable. 1) verify connection between display board and touch panel (2 ribbon electrical cables).make sure the cables are completely seated into the connection point both ends. If the cables are connections check ok then replace the touch panel. If the problem persists still occurs replace the complete display board
Dec 05, 2016 | Electrolux Kitchen Ranges
Laptop all whit screen
Dell Inspiron 1420 Notebook PC?
The white screen can be fixed. How?
Connect a VGA monitor to the laptop. Connect to the VGA port on the right rear. Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
By default the display should show on the external VGA monitor.
No?
Press, and hold the Fn key down, and at the same time tap the F8 key ONCE.
Still no?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F8 key.
No display on the external VGA monitor, means you have a bad graphics chipset. Replace motherboard.
Display does show on the external VGA monitor, means you have a problem with;
1) Video Cable
or
2) Screen Inverter
or
3) LCD screen
Video Cable:
The Display Panel Cable (Video Cable for Dell), connects to the motherboard by the left Hinge.
Goes under the left Hinge, and up into the Display Assembly.
It then connects to the Screen Inverter, and to the back of the Display Panel. (LCD screen for Dell)
From normal opening, and closing of the laptop, the Display Panel Cable may become pinched in the left Hinge.
This can cause;
A) The connection at the motherboard to come loose
B) The connection at the back of the Display Panel to come loose
C) Stretch the wires inside the Display Panel Cable's sheath, and damage the wires. (Break)
If you are lucky just the connection at the motherboard, and/or connection at the back of the Display panel, may have come loose.
Diagnoses is to NOT just look at the connections, but physically push the connectors of the Display Panel Cable, into the connector at the motherboard, AND back of the Display Panel.
Visually inspect the Display Panel Cable's sheath. Do you see any outward appearance of damage? This means the tiny wires inside may be damaged.
Replace the Display Panel Cable.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Keyboard Cover.
Unfasten the Keyboard, LEAVING the Keyboard Cable ATTACHED to the motherboard. Roll the Keyboard over, and lay it upside down on the Palm Rest Cover,
http://support.dell.com/support/edocs/systems/ins1420/en/SM/display.htm#wp1129771
[ NOTE*
Two Philips head screws at top of Keyboard. After removing, lift the top of the Keyboard up a little, slide it a LITTLE towards the Display Panel.
DO NOT lift it straight up at first.
There are 3 plastic tabs on the bottom of the Keyboard, that slide into the Palm Rest Cover. If you pick it straight up you will break those tabs off ]
In Removing the Display Assembly, note where number 1 points to.
This is the Display Panel Cable's connection, TO the motherboard.
Note where number 2 points to. Those cables going to the Mini-Card Antenna, HAVE to be reconnected, right back to the SAME terminals on the Mini-Card. Make a mark on the cables, and matching marks on the Mini-Card.
Use the instructions in Removing the Display Bezel.
Use the instructions in Removing the Display Panel.
View the last illustration in Removing the Display Panel.
Note how the Display Panel Cable attaches to the Display Panel, and Screen Inverter
Number 2 points to the connection at the back of the Display Panel
Number 6 points to the connection to the Screen Inverter
The Black connector that is not numbered at the bottom, is the motherboard connector of the Display Panel Cable.
This is a better view of the screen Inverter,
http://www.ebay.com/itm/Dell-Inspiron-1420-1421-LCD-Inverter-Backlight-Combo-/370274752470
Display Panel Cable checks out? Look at the screen Inverter. This small circuit board is located at the bottom of the Display Panel, and behind the Display Bezel. Closer look at link listed above.
Is the cable coming from the Display Panel Cable, plugged in tightly to it?
Does the screen Inverter look damaged?
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Jun 09, 2012 | Dell Inspiron 1420 Laptop
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    6 pink lines verticle on 50 inch lg
    this problem is related to lcd panel of tv. u need to unplug the tv remove back cover of tv, have a close look at cables connected to lcd panel. disconnect the cables & connect the cables again. if problem not solved, replace the lcd panel.
    Aug 25, 2011 | Televison & Video
    I took this laptop apart to try and fix the sound jack and speakers, in the process of doing this I think I damaged a couple of pins on the flat ribbon cable with 12 pins that goes from the power button to...
    the smoke means that you have a short circuit somewhere on your laptop double check the connections that you have made you might have to replace the flat ribbon make sure there is no dust at these connections you have to keep a computer free of dust/causes static electricity otherwise it can cause it to overheat and many other problems
    hope this helps
    May 12, 2011 | Acer Computers & Internet
    The hdmi port on my Panasonic CT-30WC14 only works when I push the cable into the port and hold it. It has a bad connection. I was going to take the back panel off and see if I could connect to the port...
    Not the HDMI port,it the HDMI cable is dead.If u have dead HDMI port holding the HDMI cable wouldn't work,make no difference.Change the HDMI cable will solved ur problems.
    Sep 06, 2010 | Televison & Video
    Cable cord
    Some Flat Panel TVs do not have atsc tuners on them. You should be able to connect your unit using Component cables through. This will provide a better picture, but you will have to control channel changing through a cable box. You will need a cable box to connect your TV to cable. If you dont have a tuner you cannot just connect from the cable cord coming from the wall. What is your model number?
    Mar 04, 2008 | Televison & Video
    Frontpanel sound
    By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
    Nov 18, 2007 | EliteGroup P4M800-M7 Motherboard
    EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard Logo
    24 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Matthew Spark
    Matthew Spark
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
