Question about Biostar K8M800-M7A Motherboard
H50r32 radio wont shut off on exit - Biostar K8M800-M7A Motherboard
2013 civic hf goes to security mode and wont start after driving car and shutting it off it will not start
The system is computer controlled and it can be scanned for the fault that is causing this to happen. Talk to your local Honda service department.
Jun 15, 2017 | Cars & Trucks
2006 Ford F150 radio stays on when truck is off and keys are out.
Open one of the other doors and see if the radio shuts off, if it does you have a defective door ajar switch in the drivers door. The system that keeps the radio and other accessories on is called "delayed exit"
Dec 15, 2016 | Ford Cars & Trucks
Radio not shutting off when ignition off and doors opened 2005 Avalanche how do you troubleshoot
same on my 2004 Silverado... When exiting the vehicle I've found that I have to lift the exit handle all the way up to engage the switch behind the door panel. After doing this a few times the switch seemed to start working... (And radio would turn off...) If it does it again I'll be removing the door panel and cleaning or replacing a switch...
Jan 03, 2016 | 2005 Chevrolet Chevrolet Avalanche 1500 LS
Radio stays on after exiting vehicle
It sounds to me that there is a short in the ignition switch, since the ignition switch is responsible for the power supply for all those functions. Why didn't the dealer check that?
Dec 25, 2014 | 2004 Dodge Durango
2009 trailblazer radio will not shut off when ignition off and the driver side door is opened
sounds like a diode problem in the alternator letting current to flow backwards
Dec 18, 2012 | 2007 Chevrolet Trailblazer
Radio does not turn off when car is turned off
You have a defective door ajar switch, this tells the system that the river hasn't exited the car and to leave the accessories on, this is called "delayed Exit" The switch is located on the door latch inside the door, you must remove the door panel to replace it as as any obstructions inside the door like window channels.
Aug 27, 2012 | Cars & Trucks
My 2004 GMC Envoy's radio wont stay on after shutting the vehicle off
This function is called delayed exit, and it is signaled by the door ajar switch of any door that is opened. The system needs to be scanned with a special scanner by the dealer to see if the switch is defective in one of the doors. Since the switches are in each door and mounter inside the door on the latch it is not practical to guess and end up taking poss all the door panels off before you find the one that is the problem, if that is what the problem is to start off with, others things can cause this like a defective exit module or a shorted wire to the chassis or a broken door harness wire inside the insulator where it goes from the body post to the door.
Jul 13, 2012 | 2004 GMC Envoy
2004 olds alero radio will not turn off after you exit the car.
You have short in your brake light switch or tail lamps
Jul 23, 2009 | 2004 Oldsmobile Alero
2007 ford freestyle radio will not shut off; which fuse can I pul
This kmay be caused by a door ajar switch, the car has delayed exit, in other words when it senses the door has been opened it shuts down all the electronics, it is this way so you can listen to the radio with the key off after you park but don't exit the car.
The fuse number to pull is: #13, it is brown in color. and is a 7.5 Amp
Dec 04, 2008 | 2007 Ford Freestyle Limited
Biostar K8M800-M7A Motherboard Logo
20 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
