Question about HP Pavilion N5470 (F2407M) PC Notebook
Cant remove the screen for Pavilion n5470 laptop.
There are a few screws underneath the screen joint, but they are unreachable until the screen is removed. please help
SOURCE: HP Pavilion N5470 problem (can use the Omni X3 mainboard)
press f11 or f10 when your laptop first turns on and maybe u can reset it
Posted on Nov 10, 2008
  • 18 Answers
SOURCE: Opening laptop
Remove the two screws on the back of the hinge covers. then pry off the speaker panel/buttons in front of the screen. there are three screws that hold the keyboard in place. remove those and then remove the keyboard. there are two screws under the keyboard in the center of the unit. Remove those. There are also 3 screws that can only be removed if you pop out the hard drive. Hope this helps. I have had mine apart many times
Posted on Dec 28, 2008
SOURCE: power on password reseting
i can't remove the bios password for hp pavilion dv2000 laptop
Posted on Jan 09, 2009
cheap to fix
  • 404 Answers
SOURCE: I have an HP pavilion zt3000 laptop with an annoying
operating system is making it do so. re-install it.
Posted on Mar 02, 2009
  • 10406 Answers
SOURCE: I broke my laptop screen for my HP pavilion
Find a different computer-store with a qualified technician,
rather than risking your laptop, if you don't know 'HOW' to do it CORRECTLY and SAFELY.
Since you seem to have "saved" a bundle already,
spend some of those "savings" by renting the technician's services.
Last week, a local computer-store replaced my laptop's LCD screen,
and charged me for "one hour of labour", namely $60.
The store could have supplied a brand-new LCD screen for $200,
but they had a "used" screen on-hand, for $100.
So, "$500" seems far too expensive.
Posted on Jan 04, 2010
Removing the back of a laptop
Search online for a dismantling guide for your laptop.There are screws underneath the keyboard on most laptops.The top usually comes off first.This means removing the display.If you are hoping to fix an issue but have no idea it would be best to ask for advice on the issue.
Feb 04, 2014 | HP Pavilion G6 1d60us Notebook PC Charcoal
Replace laptop screen
1/Remove the pads underneath there is screws.
2/ Remove the screws
3/ with a thin flat screw driver flop out the front frame cover of the screen.
4/ remove all the screws holding the screen.
5/ remove the cabling.
Done
Oct 16, 2013 | Computers & Internet
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Where is the part number located on the motherboard for hp pavilion n5470? It isn't on the top right of the board. Do I have to remove the cpu and the heat sink combo to reveal the part number for
Most times it is located on a white sticker near the memory slots. One would think that is for the memory slots. Sometimes it could be anywhere and sometimes it will have MB on the sticker along with a series of numbers and letters. Sometimes only portions of the number you see on the sticker might be used to identify the board.
Try the steps below to be sure.
Write down the numbers you see on a piece of paper. Then go on ebay and in the search box type: HP Pavilion n5470 Motherboard. When the search results come back look at the motherboard part numbers and find one that matches one of the numbers you wrote down.
I looked for your board on ebay and only saw the following number for the motherboard: F2409-60903
One other thing you can do is to go into the HP Support website and instead of downloading drivers when you get the site up look around for links that will give you your warranty or configuration for your laptop that they manufactured it with. Usually they will have the motherboard part number listed in the original configuration.
Get online and got to www.google.com In the google search box type: "HP Support" or "Compaq Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look at the links on the webpage and there will be one for warranty or configuration, specifications, etc. They will require you to put in the serial number and part number located on a sticker on the bottom of the laptop. Serial number will have S/N: Part number will have P/N: followed by a series of numbers and letters.
May 18, 2012 | HP (F2409-69003) Motherboard
Screen Problem
Send it to best buy. they can fix it
Jul 15, 2010 | HP VM114UA notebook
How do I replace the hard drive on an HP Pavilion dv2214us pc notebook
remove battery
remove power plug
look for the screws with the picture of a cylinder underneath the system. unscrew them and the drive slides out.
Jan 29, 2010 | HP Pavilion dv2214us Notebook
Motherboard compatability
i doubt it as the connections to the monitor may well be different plus the laptops are very different shapes meaning it wont fit inside unlike desktops laptops are no interchangable
Aug 06, 2009 | HP Computers & Internet
Trying to open it up?!?
In addition to the screws visible outside the case, you need to get at screw(s) underneath the keyboard. By removing the hinge cover/speaker faceplate, you can remove the screws holding the keyboard in, and lift the keyboard out to get at the last screw(s).
Apr 08, 2009 | HP Pavilion ze4125 Notebook
Sep 16, 2008 | HP OmniBook XE3 Notebook
Keyboard replacement
Did you look at the gateway site for the manual? It should be in it. That is what I always do.
May 08, 2008 | Gateway 7405GX Notebook
HP Pavilion N5470 (F2407M) PC Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
