Question about Euro-Pro EP5100 Iron
Need manual for Euro-Pro Electronic Steam Press Model # EP-5500
snakehead
  • 1074 Answers
SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
Posted on Apr 18, 2007
SOURCE: Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Posted on Jul 18, 2008
SOURCE: Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Posted on Feb 03, 2009
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
A manual for as Euro-Pro electric iron model EP 470
You may not be able to get some manuals from the website but if you are able to call their call centre some assistance could be got from them.
Their customer service number is: 1-800-798-7398
Aug 31, 2010 | Euro-Pro Irons
EuroPro Steamiron
I need to find parts for the europro ep 8001
Sep 28, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro Pro Steam Generator EP8001 Iron - manual needed
Contacted Shark customer service and they emailed one. My product was the EP 8000 which is no longer produced. Sent the revised manual that is only a bit different for the EP 8001. Call them, they are very nice.
Jun 19, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro EP-8000
I have the same problem and was wondering if you found a solution?
Mar 08, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Press Model 5100
open the screws
use tester its a device.. when u connect it to electricity it glows.
plug it on and check the wires end
if one wire glows its ok..
other wise u hav to change wiring
Feb 18, 2008 | Irons
Jan 15, 2008 | Euro-Pro G6118 Iron
Jan 16, 2007 | Euro-Pro G6118 Iron
Euro-Pro EP5100 Iron Logo
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
