Question about Konica Minolta Office Equipment & Supplies
How to remove power supply cooling fan - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Well a model number would help and which power supply fan low voltage or high voltage
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 22, 2016
What does the error message C5351 mean on a Konica Minolta Bizhub 200?
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Oct 28, 2016 | Minolta bizhub 200 All-In-One Printer
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
Why cooling fans not working is there fuses for them
If the fans are not turning, check the 12 volts from the power supply. I would bet you need to replace the power supply. The power supply generates +5 v, -5 v, +12v and -12 v. The fans use the +12 v for power.
Aug 19, 2014 | Dell (6F858) Cooling Fan
Error code 5351
Motor Failure
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Citroen C4 automatic. After car has been driving then stops, the fan keeps going until battery runs dead. The AA fitted brand new battery but problem persists. Any ideas?
Most "CCC" Or computer comand controlled vehicles supply power to the electircal components automaticaly via a relay, there will be one power source with the ignition off,& a second power sourse when the ignition is turned on,In this case the temp sensor will supply a ground to the cooling fan circuit when the engine temp reaches a specified temperature and the fan comes on. In my opinion you most likely have a relay that has malfunctioned(gotten too hot & fused internaly) find your engine cooling fan relay(s) & remove them.If the fan stops you may have found your problem.to check the power supplied to the relay you will need a simple test light, connect the clip to a good ground & probe the relay socket with the tip of the lights probe. where there is power the test light will light up. Ignition off-1 power source,Ignition on-2 power sources/ to check for the ground supplied by the temp sensor connect the test lights clip to a battary+ source & probe the relay socket again if there is a ground supplied the test light will light up, there may be more than one temp sensor in the cooling system.you should be able to aquir a wiring diagram online if you do not have a book.one of the sensors sends the temp signal to the gauge in the dash, & the other is the ground supply for thr fan relay. I hope I have been of some help.
Dec 15, 2012 | Cars & Trucks
Ir400 fan numbers
II. FANS
A. Arrangement and Functions
Feeder fan
Fixing assembly heat discharge
fan 1***
fan 2 ***
Laser driver cooling fan
Laser scanner motor cooling fan 1
Laser scanner motor cooling fan 2
Cleaner heat discharge fan
System cooling fan
Reversing guide cooling fan
Low-voltage power cooling fan 1
Low-voltage power cooling fan 2
Reader cooling fan 1
Reader cooling fan 2
Drum cartridge cooling fan 1
Drum cartridge cooling fan 2
Drum cartridge cooling fan 3
DC controller PCB cooling fan
Scanner motor cooling fan
Function
Draws copy paper to the feeding
belt. Helps feeding.
Discharges heat from around the
fixing assembly.
Cools the laser driver PCB.
Cools the laser scanner motor.
• Cools the laser scanner motor.
• Insulates the drum cartridge
against heat from the fixing
assembly.
• Discharges heat from the
drum cleaning assembly and
fixing assembly.
• Discharges heat from the DC
controller PCB.
composite power supply and the
DC controller PCB.
Prevents curling of paper.
Discharges heat from the lowvoltage
power supply.
Cools the reader (image processor
PCB, laser driver PCB).
Cools the drum cartridge.
Cools the DC controller PCB.
Cools the scanner motor.
Aug 28, 2012 | Canon imageRUNNER 400S Copier
How do i fix a broken cooling fan
Probbly not repairable. Remove and replace it.
In your power supply? ... probably should replace the power supply with a upgraded edition. You can get the power supply apart ... but there are dangerous voltages inside and you may not find that fan anyway. New upgrade power supply is a better place to spend your hard earned $ and time.
Id not run it until the fan is replaced. Heat is the death of computers
Oct 04, 2009 | E-Machines eMachines Desktop PC
Cooling fan replacement for my hp 6624A dc power system
TAKE 9VOLT BATTARY TO SEE WITCH WAY THE AIR BLOWS, UNLESS BY LOOKING AT THE POWER SUPPLY HOUSING AND UNDERSTANDY WHAT THE ARROWS ON THE CACE SHOWS DIRECTION,
DO YOU HAVE VOLT METER, YOU NEED TO TEST TO FIND OUT OUT WHAT 12VOLT + OR - IS ON THE POWER SUPPLY , SOMETIME FAN MANIFACTURE WILL GIVE A CABLE TO PLUG INTO YOUR POWER SUPPLY TO MAKE YOUR FAN TO OPERATE THE RIGHT WAY, IF YOU NEED MORE HELP WITH THIS YOU CAN CONTACT ME THREW THIS SITE
CANDYMANGANDY
Jan 27, 2009 | HP (D6021-63034) Fan Assembly
46 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
