Question about Konica Minolta Office Equipment & Supplies
How to remove cooling fan on konica minolta - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Sir, Well a model number would help and which power supply fan low voltage or high voltage
Posted on Jan 22, 2016
3 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Konica Minolta bizhub 161f remove fuser
Usually a fuser unit isn't a replaceable item by the end user. It requires a service technician to repair because they are wired to a circuit board and there are glass components in them that have to be handled carefully.
Posted on Jul 03, 2008
xeerie
  • 347 Answers
SOURCE: KONICA MINOLTA 7416MFG saying paper jam but i
the door or cover is not properly closed or it may still have piece of paper inside it.
Posted on Jun 19, 2010
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
I have error code c -d281 in minolta bh 421
Cooling Fan for the over control board is in operative FM-10. Or the board the fan is cooling is bad. That will be some serious bucks!!!! Fan not to bad. Check for local Konica Minolta dealership
Oct 24, 2015 | Minolta Office Equipment & Supplies
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
My Kinoka minolta biz center c280 is giving me a c 5370, please help fix
MFP control board cooling fan motor's failure to turn. Located in the rear of the machine. Remove back cover. 3x3 inch fan remove dust or replace
Jun 21, 2014 | Konica Minolta Bizhub C280 Color Copier /...
Erra code SC42-18
Your LASER in the machine has a Cooling Fan issue clean it or have the fan replaced. Recommend a tech do this might require a lot of assy. removal
May 22, 2014 | Konica Minolta Konica Bizhub Pro 920 Toner...
Hoe to solve c4301 error code konica minolta 451
Fan that cools the Print Head (Which houses the LASER) is dirty jammed or burned out need to be replaced. requires lots parts removed to get to.
May 01, 2014 | Konica Minolta bizhub C450P Laser Printer
Hoe to solve 4301 error code konica minolta 451
Konica minolta bizhub c252 error c-5351
Feb 22, 2013 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 350 error code c5352
Cooling fan check the rear of the machine. Looking at the back lower left side remove the rear panel top pane has to be removed also there is a filter with that fan due to age got stuck in the fan remove it blow out fan with air, tape the filter to the metal frame instead of putting it on the fan frame out or inside. or the fan is bad worse case the control board is bad$$$$
Jul 17, 2012 | Minolta bizhub 350 Black and White Copier
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
