Kenmore 110 92587210
Water doesn't fill the machine and it stops.-hardly any water.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 21, 2008
  • 23 Answers
SOURCE: Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Posted on Apr 01, 2009
  • 240 Answers
SOURCE: Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Posted on Apr 28, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 300 won't start spinning after water fills
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this helps you.
Posted on Jul 18, 2009
canbruce75
  • 1776 Answers
SOURCE: my washing machine will not hold water
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Posted on Sep 13, 2009
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Washer doesn't stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Kenmore Washing Machines
Kenmore elite washer does not stop filling up with water, it over fills and floods until you push the the button in and then it will stop?
those machines have a water fill tube that mesures the water level it could have gotten stuck some how open the top of the machine and see if you can see the tube then rinse it out then try again should work fine
Aug 18, 2011 | Kenmore Washing Machines
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 20, 2011 | Kenmore 24042 Top Load Washer
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Over running water fill
You have a bad water level selecter switch (Load size) you will need to replace. It's not hard, located inside the console and does not cost much.
Oct 09, 2009 | Kenmore Washing Machines
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
