Question about Microwave Ovens
Need replacement fuse for daewoo kor-811q - Microwave Ovens
MicrowaveSvc
  • 9047 Answers
SOURCE: I NEED A REPLACEMENT GLASS
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts.
Posted on Dec 07, 2008
SOURCE: user manual
Download the manual here:
http://www.nodevice.com/user_manual/daewoo/microwave_oven1/kor-630a.html
Posted on Feb 10, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: How to change light Daewoo KOR - 63F7
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 20, 2009
  • 119 Answers
SOURCE: my DAEWOO KOR-1B4H. BLEW A FUSE WHEN I OPENED THE
which fuse has blown, was it in the plug or in the microwave itself?
Posted on Feb 17, 2010
mcdevito75
  • 1970 Answers
SOURCE: i need a plate for my daewoo microwave dont have a
mcdevito75 here, Contact Daewoo online or by phone thru your Owner manual.
Posted on Jun 28, 2010
Daewoo KOR-1N0A microwave oven not heating
This is most likely the fuse in the high voltage magnetron circuit (that is the microwave generator). This fuse is usually inside an inline plastic case that can be opened for replacement. Don't attempt this unless you have some experience and can work from just this clue. Otherwise take it to a professional repair shop.
I would guess it is only worth repairing if you think this may have been caused by overloading the oven (i.e. putting something metallic in the oven). If not then the fuse may have blown due to another problem and you would be better off to buy a new microwave oven.
Apr 04, 2014 | Microwave Ovens
Where are fuses located
It's normally in the power plug. you probably would need a screw driver to take the fuse out. check the AMP and make sure while replacing the correct AMP fuse is placed. hope that helps.
Jan 27, 2012 | Daewoo KOR-630A Microwave Oven
I need a plate for my daewoo microwave dont have a part number the modle number is kor - 1b4h
Jun 28, 2010 | Daewoo KOR-1B4H Microwave Oven
My DAEWOO KOR-1B4H. BLEW A FUSE WHEN I OPENED THE DOOR. CAN I FIX IT MYSELF?
Feb 17, 2010 | Daewoo KOR-1B4H Microwave Oven
Thermal fuse needs replacing.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjkj
Apr 18, 2009 | Daewoo KOR-630A Microwave Oven
I NEED A REPLACEMENT GLASS PLATE FOR MY DAEWOO MICROWAVE OVEN MODEL#KOR-1B4H
Dec 07, 2008 | Daewoo KOR-1B4H Microwave Oven
User manual
Sep 29, 2007 | Daewoo KOR-630A Microwave Oven
Daewoo microwave won't turn on
If this really is an 8-year-old 600W oven, then I would think it's really not worth putting time and money into... The technician in me hates to say that, but there are times when that's just the right answer...
Oct 19, 2006 | Daewoo KOR-6115 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
