Question about Frigidaire FAFS4473LR Washer
The Frigidaire fafs4473lro stopped and gave an error code EF2
I cleaned out the bottom drain and pump. All hoses are good to go. When I try to start a wash, it gives me "PAUSED" and won't start. Any help is appreciated
3 Suggested Answers
RixsFixes
  • 2200 Answers
SOURCE: Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
SOURCE: My Frigidaire Affinity washing machine says it
my affinty washer is stuck in pause mode
Posted on May 02, 2010
What is the ef2 error code
Good Afternoon Friend,
I understand you are receiving an EF2 error code on your Frigidaire washer, model# GLTF2940ES. The EF2 code states that too much soap was used. I suggest running a cycle without any soap and any clothes in it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire GLTF2940ES Front Load Washer
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire washer has e21 error code and wont start
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
My atf8000fsi washer keeps pausing. It will not complete any cycle. I have to sit right by it and keep hitting start. It seems to keep restarting the cycle but never spins or completes the cycle. The last...
EF2 on a Frigidaire washing machine indicates too much soap which could mean the pressure chamber is blocked or the pressure switch is held closed for some other reason. Try removing the small bore hose from the pressure switch and listen for a click when you do so, if there is a click it will indicate you have a pressure chamber blockage. The chamber will need to be removed and cleaned out don't just blow into it via the attached hose because it will block again after a few washes
Mar 29, 2017 | Frigidaire Affinity ATF8000FS
Error E21 won't start washing delay then won't spin all the water out
Hi, water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump.
Drop the bottom front panel. The pump sits on the right side. Disconnect the drain hoses and clean them and the pump impeller out.
Oct 02, 2010 | Frigidaire Washing Machines
Trouble code e20
Water not draining fast enough. Try holding the Start/Pause and Cancel key together for 3 seconds. The Door Lock, Wash, Rinse and Final Spin LED’s should light. Any error codes should be displayed when pressing the Start/Pause and Cancel keys.
Remove the bottom front panel. This can be done from the rear of the machine by unscrewing the 2 securing screws. The pump sits on the right side. Disconnect the hoses and clean them. Make sure to clean the pump impeller out as well.
Oct 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Hi
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
EFO, E10 error Message
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Frigidaire FAFS4473LR Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
