Question about Star G12-Y 'Galaxy'' Popcorn Maker
G12-Y galaxy popper will not heat up - Star G12-Y 'Galaxy'' Popcorn Maker
    Habit-Forming:
    New Friend:
  • 70 Answers
Unplug the kettle and check voltage at the kettle reciprocal . If correct voltage is there with the kettle switch on put a ohm meter across the hot and neutral terminals of the kettle plug . If there is no continuity between them either a wire burned off in the kettle or the thermostat is bad. When they go out its usually open so no power will go thru it.
Posted on Aug 21, 2016
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
The Kettle Agitator gets stuck. Appears the Rotating Center is Wobbly. . .
The motor output shaft bushing might have came loose I have seen where it falls out of the motor and the shaft becomes real wobbly and it will cause excessive wear in the kettle cross bar bushing too. also make sure the cross bar and lid assy. is not come loose from the kettle.
Feb 27, 2016 | Star Manufacturing Star G12-Y - Galaxy...
Can we get a replacement kettle for this model
NOT SURE HOW OLD THAT IS . IT IS LIKELY STAR SELLS REPLACEMENT KETTLES FOR THAT BUT ONCE YOU SEE THE PRICE YOU WILL WANT TO HAVE THAT ONE REPAIRED. YOU CAN SEND IT TO ME AND I WILL LOOK AT IT FOR YOU.
Oct 16, 2015 | Star G12-Y 'Galaxy'' Popcorn Maker
What is Amyl Nitrate poppers
Dangerous.
Amyl nitrite, also known as 'poppers' is a short acting inhalant, causing vasodilation, accompanied by an intense rush, euphoria, and a sensation of heat and excitement.... Amyl nitrite and other compounds of the alkyl nitrite -popper- family have been part of the club culture from the 1970's disco scene up till current times.
Al you need to know is here. Amyl Nitrite Drugs Forum
Jul 15, 2014 | Computers & Internet
Popper does not work when plugged in
the heat coil shorted the fuse blew; throw it away
Dec 03, 2013 | Kitchen Appliances - Others
New Cuisinart Party Popper not heating
Align the tabs on the plate with the rectangular indentations on the base.
Squeeze tabs, set plate on base and release. This should lock the two pieces together.
Mar 29, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Galaxy popper g12 unpopped kernels
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
Jan 13, 2009 | Galaxy G18-AT Popcorn Maker
Star G12-Y 'Galaxy'' Popcorn Maker Logo
260 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
