The belt on my Pioneer CT-9R has slipped off the left hand side flywheel. Can the belt be repositioned easily or do I need to see professional help?
  • Audio Player... Master
  • 1,267 Answers
If it has slipped off then the belt is too loose so you will need to replace it. Too many people try and put ONLY a new belt on and forget all the rest of the work a deck needs. They are only successful for a very short time if at all. I have been working on tape decks for 45 years and have seen just about all brands. Look for a shop that specializes in tape deck repair.
Posted on Aug 02, 2015
  • 104 Answers
SOURCE: Pioneer CT-w602r
once you see the mechanism the flywheel is the largest 'dull' silver colered disc you can see. somtimes a cassette mechanism can be helped along by moving this disc with your index finger.
if it recovers, you have bought a little time but the belts must be replaced. You will need a pro to replace the belts or a really mechanically inclined friend.turntableneedles.com has over 450 belt sizes but they show no listing for your model as of yet. so you would have to provide belt length info to get the right belt sizes.
Posted on Feb 11, 2009
  • 189 Answers
SOURCE: Is there a manual available for Pioneer CT-5310 please? +CT-W650R
HELLO
For FREE manual downloads try a site on the web called diplodocs.com
You'll have to fill in a small questionaire on the item (takes seconds) before you can download!
Hope this helps you!
Posted on Apr 20, 2010
Grubhead
  • 5391 Answers
SOURCE: I need a complet set
Just measure the diameter of each belt (in mm) and then search with Google. Belts are generally not maker specfic.
Posted on Aug 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: I need a diagram that
A simple search engine found the procedure...
http://www.youtube.com/watch?v=Q-TPh_PxkvU
Posted on Jun 29, 2011
skywavebe
  • 1267 Answers
SOURCE: I need instructions for replacing belts in a Pioneer CT-F550
There are usually NO instructions per se that Technicains read to do this kind of work- in 40 plus years of service I have never seen any. You take off what is needed and sometimes the cassette drive mechanism out of the machine to get to the area the belts go around. Replacing belts is not the only thing that is needed you also need to oil bearings, clean pulley and flywheels and clean lubricate slide plates and cam gears if there are any. It is not a 5 minute job.
Posted on Nov 29, 2012
How do i install belts on a pioneer ct-4 tape deck
You take the deck block out of the chassis and then removed thrust plates and other parts to gain access to flywheels and other areas.
It takes time to get into these but it is not impossible.
Aug 21, 2014 | Pioneer Audio Players & Recorders
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
Belt replacement pioneer cassette
These decks don't just need a replacement belt but a lot of other things. They are not often worth repairing but that is left to the owner and how much they want to spend to get it fixed.
Sep 28, 2013 | Pioneer CT-W103 Single Cassette Deck
I have a Nordic Track Commercial 1300 eliptical that started slipping when we used it. We tightened the belt but it didn't help. What else could be wrong?
Step 1
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Step 2
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Step 3
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
sincerely. Merry Christmas.ernesto cuadra
Dec 18, 2011 | Nordic Track Exercise & Fitness
How do you replace the serpintine belt on a 1998 contour?
Open the hood and locate the belt tensioner. The serpentine belt drive is located on the front of the engine on the passenger side of the engine compartment. The spring-loaded belt tensioner on the 1998 Contour is located slightly to the left of and below the water pump pulley
Release the tension on the belt using the serpentine belt removal tool. On vehicles equipped with the 2.5 liter V-6 engine, snap the 3/8 inch-drive adapter onto the removal tool. Slip the tool into the square, 3/8-inch hole in the end of the tensioner arm. Rotate the tensioner clockwise to release the tension. While holding the tensioner back, remove the belt from one of the pulleys. Release the tensioner, remove the belt from the remaining pulleys and pull it out of the engine compartment
Snap a13 mm socket adapter into the belt removal tool for the 2.0 liter, four cylinder Contour. Place the tool onto the 13 mm bolt that holds the tensioner pulley to the tensioner arm and rotate the tensioner clockwise. While hold the tensioner back, slip the belt off one of the pulleys. Release the tensioner, slip the belt from the remaining pulleys then remove it from the engine compartment
Route the new belt around the pulleys, according to the belt routing guide. The belt routing guide on the 1998 Contour is located on a decal on the left (passenger side) strut tower. If this decal is missing, or unreadable, the belt routing guide can also be found in your service manual. Rotate the tensioner pulley one more turn to allow the new belt to slip under the tensioner pulley.
Check the belt for proper alignment on the pulleys. It should lay flat on the pulley and not overhang the edges. If the belt must be repositioned, release the tensioner and reposition as needed.
Sep 18, 2010 | 1998 Ford Contour
Pioneer CT-w602r
Dec 11, 2008 | Audio Players & Recorders
263 people viewed this question
 Grubhead
Grubhead
