Question about RELIANCE ELECTRIC WATER HEATER
Where is the reset button on the giant 152ete-3f7m water tank
  • Reliance Master
  • 5,245 Answers
2 Suggested Answers
SOURCE: Thermostat and reset button (GIANT 152ETE) - no hot water
I have the smae problem but my element on top works fine it is the element on the bottem that does not go on so what is it that i have to change the element or the thermostat. on the bottom or the one on top. I have voltage on the top but none on the bottom element and are they suppose to go on the same time.
Posted on Apr 16, 2010
Why does the reset button on one of the tanks keep kicking when no water is being used?
The tank is overheating when not in use. If it is an electric water heater, you must replace the upper and lower thermostats as well as the high limit(reset button). If the tank is 10 years old or more, you may want to replace it rather than fix it as the average life of a tank is about 10 years before it starts leaking.
Mar 03, 2016 | Water Water Heaters
Giant 152ete 3f5m. TRYING TO FIND MODEL NUMBER FOR BOTH HEATING ELEMENTS FOR THIS PARTICULAR MODEL
is it a standard water heater? if it is 1500 watt is the norm. also watt should be right on the front of element in water heater
Jan 20, 2014 | Water Heaters
Have to reset heater button
possible bad heater element or ignitor
Dec 07, 2013 | Little Giant Water Heaters
High limit switch gas hot water giant
Tank-type Gas water heater: high limit can the FV system, the ECO-TCO reset located on front of combustion chamber, or the one-time-use ECO located in the gas control valve thermostat probe.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-20.jpg
http://waterheatertimer.org/images/Gas-valve-ECO-124.jpg
Tank-type electric water heater has a reset button:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Other types: Tankless, indirect, boiler, solar assisted, hybrid, etc, please refer to product manual or add comment and describe the product in detail
Apr 07, 2013 | Water Heaters
Water heater no hot water
1) Copy following link for troubleshooting newly installed electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
2) Push in rest button on upper thermostat.
Jan 18, 2013 | Water Heaters
Water heating not heating water
The Emmerson W152 is ordinary 1-year warranty 120Volt electric storage water heater, except with bronze tank. The bronze tank will not rust, and therefore tank does not have anode rod, and tank has 5 year warranty.
http://waterheatertimer.org/pdf/Emmerson-point-of-use-water-heater.pdf
Actions to take:
1) Check circuit breaker.
2) Emmerson plugs into 120V outlet. See if outlet works for other 120Volt light or can opener.
3) Turn off power and do following:
4) Open cover on water heater, and press in reset button.
If reset will not reset, then replace thermostat with ordinary generic thermostat from hardware store.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) If reset button is not tripped, test element.
6) Emmerson has 1500 watt element, and correct ohm reading at 120 volts should be around 9.6ohms
http://waterheatertimer.org/How-to-test-water-heater-element.html
7) This element is 7" long, and is also generic, and should be available at hardware, or plumbing supply, or Google-search 'Emerson appliance water heater element.'
Jul 29, 2012 | Emerson InSinkErator W-152 Point-Of-Use...
I have a giant hot water heater which is 12 years old and it provides hot water for only one normal shower. Why so little heat? Does it need to be replaced or is there something else that should be...
You probably need to replace the water heater. Water heaters accumulate a build up of lime and other mineral deposits that are present in water. This covers the bottom of the tank and heating elements over time, and makes them operate inefficiently. Draining the tank periodically helps prevent this from happening, but once it has reached to point you explained, it is best just to replace it with a new one.
Dec 27, 2009 | Water Heaters
Jun 15, 2009 | RELIANCE ELECTRIC WATER HEATER
Top element only working
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
so... set them both at the temperature you want the water to be... about 120^F.
Apr 02, 2009 | Water Heaters
RELIANCE ELECTRIC WATER HEATER Logo
409 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
