Question about RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black
I am unable to get HD on new tv
I have tv hooked up to cable directly, no cable box. I cannot rec. HD channels only analog. I have a spliter going to bedroom to another tv it picks up all HD Channels. But the RCA will not help me please
SOURCE: RCA Scenium HDLP61W151
RedRacer guy, you are awesome! I had the same problem as the 2 other people with this issue. I did the reset on the "reset all" on the ethernet connection not expecting this to do anything and as I exited this, the TV came on!
Thank you, Thank you, Thank you!
Posted on Mar 21, 2008
  • 10 Answers
SOURCE: RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
Posted on Dec 22, 2008
  • 24 Answers
SOURCE: i AM UNABLE TO WATCH TV, PLAY GAMES OR MOVIE
Does it have sound?If not there is a small surface mount fuse on the video board that needs replacing.To do this on most mdels the LCD display must be removed to access the video board.NOT a DO it yourself job!
Posted on Jan 11, 2009
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
  • 8457 Answers
SOURCE: Hooked my L32HD35D to a digital cable box. TV
Try it with the HDMI cable.The RCA component cable some time it don't work.
Posted on Jun 28, 2010
I have a Samsung hdtv but its not playing in hd.I have it hooked up to cable straight from the wall bypassing the cablebox.Is it the tv or cable?
You do not indicate if you have auto programmed the television to get digital channels, If you are selecting a channel without a decimal point, for instance 82.3 is NBC hd in my cable system. If your cable provider does not produce these on direct cable then you can not get HD without a box.
Try to Auto Program your tv in the cable mode STD format, this can take up to 20 minutes to complete scan including deleting scrambled channels. After programming try the lowest or highest analog channel like 2 or 70, channel down or up from there to see if any digital channels appear.
Mar 01, 2013 | Samsung Televison & Video
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
We have used this TV as a primary hooked directly to the cable box. Now we bought a larger Sony and want to put this one in another room. We unplugged the set from the cable box carried it to the other...
first, be sure the cable outlet is working. If so then you have to reprogram the tv by doing a channel search in "analog" since it's no longer connected via a "digital" box. Just go to the tv menu, search channels(analog) and start.
Jul 21, 2011 | Televison & Video
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
I had cable when the analog went out, do I have to have a converter box for this tv?
First off here is a site listed below that gives you the specifics on this TV. I would highly suggest you review it.
http://www.epinions.com/specs/TruTech_PLV16190_Television
From what I see it only has a Standard NTSC TV Tuner just like old TV's had so it won't receive any new digital or HD channels if you choose to plug your Cable 'Coxial' RF input directly into the RF Tuner input.
The specs say it will display 720p the lower formatted HD signal but with an Analog NTSC tuner I don't see how it can display it for you.
The only high resolution input you have is an S-Video input that you could connect up to a Cable box with but again S-Video isn't going to give you High Def only the lower 480 lines of resolution.
So to answer your question. It you wish to view any digital channels 'yes' you will need a converter box for this TV.
Blessings,
A/V Media Guy
Nov 23, 2009 | TruTech PVS2119 19 in. LCD Television
My picture is not good. I'm hooked up to digital
to get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Jun 16, 2009 | Sanyo Televison & Video
Conversion to DTV from analog
IF YOUR UNIT HAS AN ATSC TUNER THEN IT IS HD READY. SEE YOUR OWNERS MANUEL. HOOK THE ANTENNA TO THE RF (ANTENNA) CONNECTOR .GO INTO THE MENU AND AUTO PROGRAM CHANNELS. GO TO CHANNEL 5 AND SEE IF YOU HAVE 5.1 OR 5.2 IF SO YOUR DONE.
Jan 30, 2009 | Akai LCT2721AD 27 in. LCD Television
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Programming digital channels
The problem is not with your TV. You need a digital box to unscramble the channels.
Oct 28, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black Logo
22 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
