Question about GPX Hc221b Micro Hi-fi System
Line in no sound when plug is removed
Removed and replaced one 1993 previa fuel injector now engine sounds "seized".Doesnt even turn Could it be vapor lock?
no
more likely a hydraulic lock from excessive fuel on a piston cause by leaking injector /seal
remove the plugs and see if the engine will then turn over after it sprays the fuel out of the problem cylinder
vapor locks occur in fuel lines where the fuel boils off filling the line with air and locks the fuel by not allowing flow in the line
Feb 25, 2017 | Cars & Trucks
After a power outage, when I am on one line and the 2nd line rings, I hear the ring on line 1 as a loud clicking noise. What could be the problem? Thanks
Check the lines using a hardwired phone plugged into the master sockets, remove any extensions if possible and listen again. Make sure if you have any ADSL filters installed they are removed and the broadband router if you use one.
if the problem persists you'll need to call the Service provider.
Sound like a short issue between the two lines.
Nov 18, 2014 | Lands Phones
Changint Oil on my 2001 Fatboy. Pulled drain plug and a half a cup of oil drained out. Pulled dip stick to see oil tank is still full. Disconnected drain line from tank leading to motor. Found it to be...
Sound like you pulled the wrong plug to me. The oil drain plug in under your bike. Look at the oil tank from the right side of your bike. Near the rear of the tank, there's a large hose that runs downward towards the rear of the transmission. It continues down and looks like it connects to a crossmember on the frame. If you'll look under that crossmember, you'll find a plug that uses an Allen wrench or hex key to remove.
Do not remove the oil line that goes from the tank to the engine. However, you said that you found it to be plugged. Plugged with what? If the oil infeed line got plugged, it's because something has gotten into the tank. Drain the tank and check to find out what is inside the tank.
Good Luck
steve
Aug 30, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Won't start. Was working excellent one day, then not. Changed plug, changed gas, cleaned filter. Got it running on full choke, but it would die the instant you hit the gas. Any ideas?
Sounds like a broken fuel line. I would first check to make sure you are getting spark by removing the spark plug and grounding the side of the plug on the engine and pulling the pull cord. Make sure you have spark. If you have spark then you will need to remove the cover so you can get to the carburetor and inspect the fuel lines for leakage or cracks. You should be able to watch the fuel flow through the lines while pushing the primer. Push the primer bulb and look for a broken fuel line.
I hope this helps you out.
Jun 22, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I changed the spark plugs and now it sounds like a helicopter
Does it have power???no piston should be stuck.make sure all vacuum lines are connected and everything that you removed is back where it was.sounds like vacuum leaks
Oct 04, 2009 | 1994 Honda Accord
Dishwasher wont drain
Sounds to me like your drain line is plugged .
Remove excess water from the dish washer, shop vac works great if you have one.
remove the drain line from the bottom of the pump.
Remove the hard line from the pump with a set of pliers, inside you will see a diaphragm, this is were rice or corn will get lodged causing a blockage. Remove debris, check o-rings to ensure they are in good condition, re0attach hard line and hose.
Hopefully this helps you out.
Aug 13, 2009 | KitchenAid KUDD03STSS Stainless Steel 23...
Dishwasher backing up
sound like you have a few things going on there.there is a float switch which is located at the front right side of dish washer, make sure this floats freely . also sounds as through your drain line may have become plugged. Ease to fix , remove the line and hard line from the pump with a set of plyers. and remove the debris from the diaphram within the hard line.. before starting this be sure to remove as much water from within the dishwash, easiest way is to use a shop vac.
Jul 26, 2009 | Kenmore 15912 Built-in Dishwasher
EARPHONES NOT ABLE TO PLUG INTO MONITOR.
Hi, I hope you've solved the problem.  But if the first solution does not work for you maybe this one will.
I looked at the specs for your monitor. LINE IN is for plugging in a device that makes sound, so this is not the right hole (called a jack) for the headphones plug.  Look on the back of your computer for a hole that is outlined with light green.  You wrote that you removed " the audio wire that connects the monitor to the CPU", this would be the place to plug in the headphones.
May 21, 2009 | Hannspree Hanns.G HW191D 19 inch...
We are disconnecting our dishwasher to remove it. The electrical line comes out of the wall but not with a plug in. Is it connected to the front of the dishwasher somewhere how do we disconnect it?
It sounds as if the cable is wired in. It is unusual for there to be a plug in at the dishwasher end. Have you traced the line to where it enters the dishwasher? Be careful this line will be live. You may need to have it disconnected at the wall outlet.
Oct 10, 2008 | Dishwashers
GPX Hc221b Micro Hi-fi System Logo
Top GPX Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a GPX Furniture Expert? Answer questions, earn points and help others
