Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
FLASHING CLEAN LIGHT AFTER INSTALLING CONTROL BOARD
My clean light is flashing and the lock light is on, on my whirlpool dishwasher. I've tried the reset code of HD/N/HD/N and it didn't work! What can I do?
What is the model? If you take the panel off you can test the control board and controller by unhooking the ribbon cable from the controller to the keyboard. Then close the door. If the pump comes on, it is the control panel, if the pump does not come on it is the control board.
Jun 04, 2013 | Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
The "clean light" is flashing
Indicates control hasn't sensed a rise in water temp during heat cycle. Make sure you hear the water being circulated during wash cycle. If so the heater, control board, thermostats or wiring are most likely bad. If heater, therms, and wiring check good its usually the control. When fixed press Heat dry- Normal-heat dry-Normal or High temp- air dry-high temp- air dry to reset control.
Sep 25, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
The green light which goes off at the end of the cycle is continually flashing and there is a continual beep.
You may just need to reset your control board. Go to the link and it will explain how to reset the control board as well as explain what might cause the issue and how to fix it.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good Luck
Mar 06, 2011 | Whirlpool DU930 Built-in Dishwasher
Replaced the control board of my quiet partner
clean light flashing is a power interuption between the heater and the control often its is actually the door switches from not closing the door evenly but a chance that the heater is bad.also if you replace the main ccu it should have a software update that buypasses the fault and a good start wouldd be to reverse the door switch and test your heater for ohm values you want it to ohm out
Jun 02, 2010 | Dishwashers
Green light on my whirlpool dishwasher comes on at the start and then starts flashing
This clean light indicates a failure for the water temperature to rise, I put together a list of things here that can cause it and how to reset the control so you can use the dishwasher, let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Mar 21, 2007 | Kenmore 24 in. 17019 Built-in Dishwasher
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
15 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
