Question about White-Westinghouse White Westinghouse Mini Food Processor Chopper Mince Slice Shred Disc
I can't remove the bowl on my mini chopper to clean it
How to remove the bowl of the mini chopper. THe bowl is loose but the blade won't releaae
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
Small engine won't start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Feb 09, 2012 | Garden
BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
May 16, 2010 | Wolfgang Puck BIBC1030 Blender
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
Top spray not functioning in dishwasher
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 09, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Have trouble getting it to start
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Mar 04, 2009 | KitchenAid KFC3300 Mini Chopper 3 Cups...
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Cuisinart MM-2 Mini Mate Chopper/Grinder - Instructions
In order:
Yes, you must twist off base to remove blade - only twists one way, not the other
Yes, instructions online/manual:
http://www.cuisinart.com/share/man/72_man.pdf
SRP - $79.00
Current Price - about $40.00
Orig manufactured 2003, but the first # in serial # will tell you your exact manuf. year, 3 = 2003, 4 =2004 etc
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Nov 16, 2007 | Ultimate Chopper Food Processor
White-Westinghouse White Westinghouse Mini Food Processor Chopper Mince Slice Shred Disc Logo
44 people viewed this question
Top White-Westinghouse Dishwashers Experts
Are you a White-Westinghouse Dishwasher Expert? Answer questions, earn points and help others
