Question about Primera Technology LX400 Color Label Printer (P/N 74261)
Labels are blurry
Just added a new ink cartridge, now the labels I am printing are all coming out blurry. I tried to print 20 or so in hopes it would work itself out, but no dice.
4 Suggested Answers
edisonfrelan
  • 113 Answers
SOURCE: Primera Bravo CD/DVD printer -- prints blank
Let the printer repair itself. Got to start menu select the printer then select properties. Go to maintenance menu try all the basic testing. If it still didn't work out, delete the previous driver and install it again, then restart and try printing again.
Posted on Dec 14, 2008
jomabug76
  • 1148 Answers
SOURCE: I have a Bravo SE printer at work, but when ever I
be sure to not only print an alignment page but do the head cleaning options on printer tools/properties,,should help,,or even correct ur problem
Posted on Nov 08, 2010
Testimonial: "Thanks, it didn't fix it, but the print that way looked perfect so I knew it was a setting issue. I changed some settings and it looks fine now :)"
drifterK
  • 4924 Answers
SOURCE: Hi i own a Primera
If the paper runs trough the printer ..and the printing goes as it should ..but just no image gets on the paper..it is usually a fault with the cartridges..If they stayed unused for a while ..they are dryed...and you will have a hard time making them work again ..Even if some ink seams to get on a cloth or so ...if on the paper it is not getting enough ..it will print like this..If no other error is on ..you will have to change the cartridges..If you use recharged ones..I suggest to recharge them ..and try to add and remove ink from them ..a few times to moist the sponge inside..If you use a syringe just fill 'em up ..and after that blow air inside to mix the ink ..or ..just get new cartridges..
There can be another fault The wire inside the drum ...If it is broken ..it will not charge the drum magnetically ..and this can be a issue too ..In this case you have to see if there is a corona wire available for your model ..or change the drum ..
Posted on Aug 18, 2011
Black text printing blurry
if new take it back for a warranty check / exchange or refund
Nov 30, 2016 | Office Equipment & Supplies
How do I cure blurry printing please?
You don't say what type of printer you have (some have built-in utilities that can guide you to correct things) but generally speaking, if text print is coming out blurry, you may want to look at the following:
1) Check your ink cartridge. Is it dirty? Is it plugged (clogged)? A good cleaning may help by removing your ink cartridge and swabbing the print head nozzle (check your manual for location) with isopropyl alcohol with a cotton Q-tip. Run a test print. Still a problem? You may need to do this about 3 or 4 times before it clears. If your printer head is way down indide the printer, you can get an eye dropper and drop some isopropyl alcohol on it.
2) Check your quality settings. Perhaps someone had changed the settings from "Best Quality," for instance, to "Draft." Make your changes and click Save. Run a test print.
3) Check your paper type. Do you have the right type of paper for your printer? Inkjet printers require inkjet paper, whereas laser printers require laser paper. Mixing the two will produce poor print quality. I am assuming you have normal copy paper in your printer tray, which is fine.
4) Check for printer software updates. Have you tried reinstalling your printer again, especially your printer drivers? If your printer is an older model, perhaps a software update is needed. Go to the manufacturers website and see if there are any new print drivers for your model. Run a test print.
5) Replace your print cartridge. This could simply be an issue of your cartridge being too old, drying up or defective. After installing new cartridge, run a test print.
Hope this helps!
Pen
Aug 14, 2014 | Epson CX9300F/CX9400Fax/DX9400F
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I am installing a new ink cartridge. The printer
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Office Equipment & Supplies
Hp psc 750 won't print with new color ink cartridge
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
Won't print PRIXMA iP1500 Going through the actions of printing but no ink appear on paper. Deep cleaning done, reset done, new cartridge done, alignment printing done, still no ink.. and it did print a...
If using aftermarket inks you sometimes have to rap them on a paper towel to break an air lock.If you see ink coming out after rapping them try to print again.If nothing comes out you may have a bad print head or purge pump.
Try cleaning the head (without cartridges)in a 10-20% ammonia warm water mixture for 30-45 min.
Completely dry the head before returning it to printer.
Jun 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Paper detection and new ink cartridge
Press the green diamond key on the face of the printer when the error message comes up and it will print
Dec 05, 2007 | Office Equipment & Supplies
Primera Technology LX400 Color Label Printer (P/N 74261) Logo
22 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
