Question about Wildgame Innovations IR4 Digital Camera
Takes pictures when nothing in sight
Camera took 200 pictures one right after the other sensitivity seems to be too light
I can record, i can take pictures inside or when it is night but i can not take pictures with the light of the day or when there is a strong light. I can see from the lcd monitor the icon bute when i take...
You have the ISO Setting set too high. This is the setting that in a film camera was called 'film speed'. The higher the ISO, the better it will take pictures in low light. Yours may be set to 3,800 ISO, when it needs to be on 200 or 400. The light during the day is bleaching out the sensor and that is what you are seeing on the screen. Also the higher the ISO, the more grain you will see in images.
Understanding ISO - A Beginner's Guide - Photography Life
https://photographylife.com > Photography Tutorials
Sep 4, 2017 - The lower the ISO number, the less sensitive it is to the light, while a higher ISO number increases the sensitivity of your camera. The component within your camera that can change sensitivity is called "image sensor" or simply "sensor".
Film speed - Wikipedia
https://en.wikipedia.org/wiki/Film_speed Film speed. ... Film speed is the measure of a photographic film's sensitivity to light, determined by sensitometry and measured on various numerical scales, the most recent being the ISO system. A closely related ISO system is used to describe the relationship between exposure and output image lightness in digital cameras ... ‎Film speed measurement ... · ‎Film sensitivity and grain · ‎Digital camera ISO speed ...
What is ISO (Film Speed)? - I STILL SHOOT FILM
istillshootfilm.org/post/592532284/what-is-iso-film-speed As I explained in How Film Works, photographic film is made up of millions of light-sensitive silver halide crystals, which we call grain. The lower the film speed, ... film iso explain in digital photography Google Search
Oct 31, 2017 | Canon PowerShot Pro1 Digital Camera
What numbers on camera screens corner that's f3.0 1/30 ISO 200
f3.0 is the size of the lens opening. The larger the number, the smaller the opening.1/30 is the shutter speed.ISO 200 is the sensitivity speed of the sensor. The higher the number, the less light you need for a good picture. For example, 400 is twice as fast as 200...800 is 4 times faster, etc.
Nov 13, 2011 | General Electric W1200 Digital Camera
Dear sir,i purcahsed d90 cam but result is not good wat can i do ? wat can do setings get good result
The d90 takes excellent pics, but you need to understand the settings. White balance determines the accuracy of the color by setting what the camera sees as whit compared to what you do. Then you need to set the ISO, which is how sensitive it is to light. The higher the number, the more sensitive. In super bright situations you may need to go as low as 200, 800 in lowlight. 400 is a good average, 100 is rarely used. then your aperature value (a/f) this determines how much light the camera actually lets in, not to be confused with the sensitivity (ISO) which is specifically how sensitive the film is (not that you have any). Then is the shutter speed, which is how long the camera exposes the film when you hit the button-for fast moving objects, you want the shutter to open and close really fast so it doesn't blur;if it stays open too long it will capture the object in motion-if someone is running and you have a slow speed, the image could be the runner taking three steps as opposed to a still picture. To start.your setting when you take a pic, look at how much light you have. For indoors with no lights on during the day or outside cloudy, ISO 400. In at night with bright lights or outside sunny day, ISO 800. Then determine the speed of your object. A good standard for slow objects is 1/20-1/60. Set that, then set your aperature (f value) so the picture looks at the right brightness. If you adjust the aperature all the way and still need more or less light, adjust the shutter. Then cycle through your white balance options to make sure your color looks right and take a picture. If it comes out really grainy, your light settings were not right, you should pay attention to your ISO and aperature settings.
Mar 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
Grainy pictures and not sharp
These cameras were designed to be high sensitive to light. If the Flash is set for Auto Flash, the camera tends to use ISO 400 whether the flash is fired or not. This was done to increase the working range of the flash.
In order to change this setting please go into the Menu (Capture+ tab) and set the ISO for 64, 100 or 200 in order to reduce the graininess. However this will lead to slower shutter speeds in low light.
Jan 28, 2010 | Kodak Easyshare M381 Digital Camera
My camera is set on autoflash but it flashes even in the bright day- light resulting in over expose, what could be wrong? It takes good pictures at night.
Yes I believe I fixed my problem. I shined a bright flash light at
the light sensing photocell and took pictures with it (no flash).
Then I darkened it, took pictures (it flashed). I did this back and
fourth and it seemed to work although I have not tried it in the
field yet. Thanks for your offer of help and I do think your
rates are reasonable.
Anthony 12-6-09
Dec 06, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My olympus stylus 770 SW digital camera pictures during day time are so bright..what should i do?
Lower the ISO sensitivity to around 200 or 400.
That's like film speed... the lower the ISO the less sensitive it is to light.
[Menu]
[Sensitivity]
(down arrow) to 200 or 400...
What is is set on? 3200??
Sep 30, 2009 | Olympus Stylus 770 SW Digital Camera
Not good photos indoors very grainy and bad light looking photos
Auto mode in poor lighting (generally always indoors without flash) sets high ISO, which produces ugly amount of noise (graininess). What you need is to keep the ISO under 200 by either:
Shooting well lit scenes, using flash etc.
or
Uusing one of the manual programs (M, S, A, P) and setting the sensitivity via the F-menu.
Dec 27, 2008 | Fuji FinePix S8000fd Digital Camera
LCD frozen
These cameras are very heat sensitive, keep them cool. If your camera is still in warranty, Canon may replace it. Good luck, I really like my 410, it's easy on batteries.
May 17, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Most of picture blanked out or blocked out
This seems to be a oricessing orblem and the process is failing to complete or corrupting. Rreformat the card in the camera Try another card.
Jun 04, 2007 | Canon Digital Rebel / EOS-300D Digital...
Wildgame Innovations IR4 Digital Camera Logo
Top Wildgame Innovations Cameras Experts
teddyboy
Steve Mason
Are you a Wildgame Innovations Camera Expert? Answer questions, earn points and help others
