Question about Dell XPS 420 PC Desktop
Where is mic jack - Dell XPS 420 PC Desktop
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
I have an audio technica wireless mic with the 4 pin connector. We have purchased a new lavalier mic but are still having trouble with tge mic maintaining a connection. It keeps cutting in and out if you...
Mic plug has been replaced (new lav mic) so that leaves the mic jack connected to the body transmitter. Corrosion is a possibility...
Radio Shack tuner cleaner http://www.radioshack.com/product/index.jsp?productId=12784986
but I think it's something to do with the mic jack on the transmitter. Some units solder these connectors directly to the internal PC board and after a while, the solder connections break. Have a tech open it up and closely inspect the input jack's solder pads.
Jan 28, 2013 | Audio Players & Recorders
Can you get dual channel audio (four Chan) out of a toshiba l300 laptop?
Yes you can just grab a cable (both ends) male jack,like the male jack of the mic jack and plug one end to the PC and the other to your audio system
Apr 30, 2012 | Computers & Internet
I have 2 plugs on my Logitech ClearChat Stereo Headset Headset I have a table top computer where do I pug them
The headphone plug goes into the green jack on the computer. The mic plug goes into the red jack on the computer. The headphone plug with have three segments on the jack, the mic plug will have two, and they'll both be marked. If you're computer doesn't have color jacks, the mic will go into the one with a picture of a mic, the headphones will go into the one with a picture of a headphone or speaker.
Jul 07, 2011 | Logitech ClearChat Stereo Headset Headset
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Broken **** jack casing
Go to specialist.It may be possible to repleace only the mic jack.
Apr 01, 2009 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525 without the webcam .. when I use my headphone jacks in the front of my laptop I'm able to hear but the they can't hear me through my headset microphone. They're only able to...
Be sure that your headphone mic plug jack is plugged in to the mic jack (right-most jack) and not the second headphone jack. If so, check your sound setting in Control Panel and make sure the mic is enabled and the volume slider for it is up.
Dec 07, 2008 | Computers & Internet
Dell XPS 420  PC Desktop Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
