Question about Curtis CM19033S 19" TV
Explain 9 jacks on back - Curtis CM19033S 19" TV
How to call outside.. by using external 2 up to 16
Has it worked before or it's a newly installed system.
Could be programming issues.
Try dialing 0 first > dial tone then outbound call.
Its either 9 or 0 depending on configuration
Jun 18, 2014 | Panasonic KX-T7730 Corded Phone
Sound fades.
Did you try a new 9 volt battery?
Feb 22, 2014 | Marshall Amplification Marshall MS-2 Mini...
How to solve charging problem
Dear, Could you explain the problem like is there a charging error display on your screen or is this problem of your charging jack.
well i can help you, if there is charging errror display on your mobile screen so your charger or your battery must be corrupt or non-geniune.
OR if there is problem with your charging jack so it is very easy to fix this problem, you just need to buy a new jack it is very cheap. Then if you can change it yourself so it is better otherwise you just go to a cerified mobile phone repairer and let him chande your jack. Changing the jack is just like 1 2 3, you just pull the jack back after opening your phone and push the new jack.
Thanks
May 06, 2010 | Sony Ericsson P990i Cellular Phone
If I enter the following equation: 1/9+1-1-1/9 my calculator displays -1E-14 but the answer is 0. Please, explain
This is because the TI-85, like any other calculator, is a finite device and 1/9 cannot be represented exactly in decimal notation.
For this discussion I'm going to use five digits instead of fouteen so it's easier to see.
1/9 = .11111
+1 = 1.1111 (note one digit falls off the right end)
-1 = .1111 (the missing digit doesn't come back)
-1/9 = -.00001
Apr 09, 2010 | Texas Instruments TI-85 Calculator
What are colored jacks on the back of my emachines
Those are audio ports. You are right about the documentation...poor.
Here is a web page that explains the differennt color codes for the ports:
http://www.hobby-hour.com/electronics/sound-card-color-code.php
Thanks for using Fixya.
Feb 23, 2010 | Computers & Internet
Do i have to raise the engine to remove the oil pan on my 1999 saab 93 turbo.
No. You jack-up the car and support it firmly on jack-stands. Also chuck the back-wheels.
Oct 23, 2009 | 1999 Saab 9-5
Lock symbol 9 costant on and lock symbols a and down arrow blinking Basicly it will not come on
For a lock with 9 push and try to hold  NumLock key right above,iy you just hit it might won't work hold it down hard.
Jun 18, 2009 | Dell 0Y3740 Keyboard
I want to listen to music from my inspiron 9 threw im310
You will want to use a 1/8" to 1/8" Stereo patch cable similar to this one http://www.radioshack.com/product/index.jsp?productId=3612891 Just plug it into the headphones jack on your laptop then plug the other end into the jack on the back of your im310.
Jun 11, 2009 | Altec Lansing inMotion iM310 Portable...
I HAVE A 5400 SERIES LEXMARK PRINTER. I MOVED MY COMPUTER FROM 1 ROOM TO ANOTHER AND INSTALLED 2 JACKS NOW I CANNOT RE-HOOK MY PRINTER BACK UP, AS SOON AS I HOOK UP THE PRINTER MY DSL WONT CONNECT. I HAVE...
Please explain the jack.
If it is a regular network jack, you need a RJ45 jack punched to the 586B wiring code (http://www.9thtee.com/networkingts.htm)
You can find these jacks and the tool you need to install it at places like Home Depot.
That is if it was using a regular network cable in the first place.
A network cable has 8 wires (4 pair) and computers communicate over 2 of the pair (inbound + & 0 and Outbound + & -)
If you were using some other type of connection originally, please explain what it was.
Jul 29, 2008 | Lexmark Office Equipment & Supplies
Curtis CM19033S 19" TV Logo
11 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
