Question about Dell XPS 420 PC Desktop
Xps 420 where is mic jack
Where is mic jack on back
whitebirch
  • 433 Answers
SOURCE: My microphone not working on my dell xps 420 vista system
double click on the speaker and make sure that the mic does not have the mute box with an x in it.
I am pretty certain you have a card in your computer for it mentions a 7.1 speaker system.
If you put your service code in to do a search for drivers you will get the correct ones for your particular machine. Download install and reboot.
If you are not using six speakers and one sub woofer then the pink one in the back is the mic
Posted on May 14, 2009
joecomputer
  • 92 Answers
SOURCE: XPS420 Front Mic Problems
Try going to the Control Panel and select Sound and Audio Device Properties. Go to the Audio tab and under Sound Recording section make sure your device is selected.
Please don't forget to rate this solution.
Posted on Jun 09, 2009
wildbear6
  • 192 Answers
SOURCE: My xps 420 pc desktop wont boot. Shut it down last
Try and reset your CMOS and see if it helps.
If you're not sure how, then unplug the power cable from your PC, then take off the side panel, on the motherboard is a set of 2 or 3 pins to Clear the CMOS (reset the BIOS) all boards are different, so there is no set location for the CMOS pins, if you're unsure, just remove the battery from the motherboard for about 30 seconds, then replace it ("+" facing up)
But you need to make sure your PS is not plugged into any external power source while you're doing this or you risk deleting your BIOS
Hope this helps in some way.
Posted on Jan 01, 2010
joecoolvette
  • 5660 Answers
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Posted on Jan 04, 2010
StuartB
  • 807 Answers
SOURCE: connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Posted on Feb 06, 2012
My XPS 420 desk top won't accept my SD card
The format on the sd card may be faulty constituting a format before it will except it, back info on sd card in a safe location and format.
Sep 10, 2014 | Dell XPS 420 PC Desktop
back up pics on sd card then format, reload pics and retry
Xps 420 fan
as long as it has the same connector than yes. fans are usually the same when it comes to personal computers
Mar 05, 2014 | Computers & Internet
Connect midi to dell xps 420
Feb 06, 2012 | Dell XPS 420 PC Desktop
Hi there i have an xps 420 computer and my mic isn't working it says its plugged in and recognizes it but no sound come out and i even tried recording and nothing happens. i tried my mic on another...
first you can check your mic is muted..just open control panel and there will get the option of sound properties after u can check there mic is muted or note.otherwise you must reinstall your audio sound card driver because this issue is same as audio driver problem.if u still have the same issue after reinstall your driver you must reinstall your operating system.if still have the same issue?? you must check your mic port of your computer.thank you.
Sep 05, 2011 | Dell XPS 420 PC Desktop
Ahhhh
if you use vist os its normal
Aug 29, 2009 | Dell XPS 420 PC Desktop
Jun 08, 2009 | Dell XPS 420 PC Desktop
May 14, 2009 | Dell XPS 420 PC Desktop
Dell XPS 420  PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
