Question about Magic Chef Chest Freezer MCCF5WBX
I have a magic chef model mcuf3ds freezer that just stopped working
Just stopped working not freezing and don't here the motor running
  • 16 Answers
SOURCE: magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Posted on Feb 13, 2009
SOURCE: I have a magic chef freezer MCCF5WBX the power
Had the same problem for the same unit. In my case, the theromostat was sticking. Mine was still under warranty so I called Magic Chef, who in turn gave me to a local repair person. In order to save him time to travel out for a diagnosis, he asked me to tap on the control to see if the run light comes on. Sure enough the run light came on and cooled the freezer. Try tapping on the unit control to see if it kicks on. My email address is mearlj@aol.com. I'd like to know if it works.
Posted on Sep 25, 2009
  • 3 Answers
SOURCE: I have a magic chef freezer that is not keeping
i have a magic chef freezer that is not getting cold
Posted on Apr 18, 2010
  • 389 Answers
SOURCE: Magic Chef MCCF5W do not works. fast freeze is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My magic chef freezer will
This is a manual defrosting freezer so the most likely cause is the temp control. Sad that is is only 2 years old but the temp control is not working correctly.
It sure sounds like it is running until it cycles off at the "I reached the cold enough" SET TEMP then never starting up again. That start up is controlled by the temp control. Call and make SURE the temp control is called the thermostat!
1-888-775-0202
  • Available 7:30 a.m. to 7:00 p.m. central time, Monday - Friday
  • The Part number is WPF24B-L and the only source is Via this link: http://www.mcappliance.com/partorder.aspx
    List Price $22.95
    Thanks for choosing FixYa.
    Kelly
    Posted on Sep 05, 2010
    Magic chef freezer model HMCF7W2 stopped working. Red power light on, freen lught off!???
    I think if it is full of food I would call for service instead of using a website that may be able to help or not.
    May 05, 2017 | Magic Chef Freezers
    WHAT MAYBE WRONG WHEN MY MAGIC CHEF FREEZER STOPS KEEPING COLD?
    Motor burnt-out, leakage, failed circuitry or temp-sensor ...
    Jul 17, 2014 | Magic Chef Chest Freezer MCCF5WBX
    QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
    Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
    Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
    Magic chef freezer model mcuf88w won't freeze
    When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
    Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
    I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
    Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
    Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
    Magic Chef MCCF5W do not works. Fast freeze is working.
    Jan 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
    THE GREEN POWER LIGHT FLICKERS, AND COOLS ONLY WHEN THE FAST FREEZE POWER BUTTON IS TURNED ON
    This sounds like the freezer stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit. Whilst sourcing the part, put a standard socket timer on to the plug to stop the unit running all the time.
    Dec 09, 2009 | Magic Chef Chest Freezer MCCF5WBX
    Magic chef freezer not working unless on "fast freeze"
    Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
    Magic Chef Chest Freezer MCCF5WBX Logo
    60 people viewed this question
    Top Magic Chef Freezers Experts
    Dan Webster
    Dan Webster
    AJMAL KHAN
    Tom Chichester
    Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
