Question about Briggs & Stratton Garden
Wont start with the key - Briggs & Stratton Garden
    Sergeant:
  • 406 Answers
If you are saying you have a good battery and get nothing no clicks try this turn the key to the on position and using a screw driver,heavy wire or jumper cable.. cross the two post on the selonoid,If it clicks and turns the starter it is the selonoid or the switch not making contact in the start position...most likely the selonoid..good luck..
Posted on Oct 10, 2014
I have a 2007 odessey and i seperated the key from the key pad now van will turn over but wont start,i put keypad back on key but still wont start turns over but wont start any suggestions?
If you damaged a chip in the key, it won't start. You will have to get a replacement. You'll need the VIN# and go to the dealer to have one cut. Wouldn't hurt to take your key with you.
Feb 03, 2015 | 2007 Honda Odyssey
Wont start
it wont start you mean it dosnt turn over no battery left or it cranks but no start clean all the keys and you should have a master key like a green one or blue with a m on it put this key in the ignition turn on the ignition without starting then turn it off and repeat with the other keys you have as well make sure its in the park position and start it after you have finish with all the keys if wont crank over try in neutral position no start fuses battery starter and so on to check after
Apr 10, 2014 | 2002 Kia Sedona
06 equinox wont start.
Did you check the relay? Maybe swap it with another and see if that works.
Feb 06, 2014 | Chevrolet Equinox Cars & Trucks
A second key was cut at a lock smith but the vehicle will not start
if the key turns and finds the spring loaded start position, fully
then the key is good.
you failed to say,
wont crank
or wont start
to diametrically different systems.
if it wont crank , it can not start, short of being push started, with manually tranny , unstated transmission, makes my comments on the key line , useless.
Aug 22, 2013 | 2008 Suzuki Grand Vitara
The security light on car wont start
You should try a different key if available. If no other key is available, you can try cleaning the chip embedded in the key
with a pencil eraser or give both the key and ingition a couple of short blasts of electrical contact cleaner.
Feb 01, 2013 | 1993 Buick LeSabre
Is reading theft system and wont start
Try cleaning your key off... those keys have security chips and if you get the oily or dirt on them your car wont start. Or try using a spare key if you have one... Good Luck!
Feb 17, 2010 | 1997 Cadillac Seville
Key is stuck in ignition and car wont start
When the battery is dead, the key cannot be removed. You can either charge the battery, and remove the key or, there is a access panel (small) under the steering column, remove this, and push a small pluger to the left, while holding the plunger, remove the key.
Dec 27, 2008 | 1997 Saturn SL
1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
rejakwilson@aol.com<<<<<<<<<<<<<<<
Dec 23, 2008 | 1998 Buick LeSabre
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
