Rexel stapler #722
I can't get the stapler open to add more staples. Is there a trick to open this stapler?
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
  • 233 Answers
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
Posted on May 27, 2010
SOURCE: electric stapler won't staple
On the side of the stapler are the instructions - no joke - stick a flathead at the lip of the metal striker and push the flat head up - while pushing the realse at the back - use A LOT of force - that is how ours popped open. It was jammed in the back with several staples that were not visible as a jamb in the front where the staples come out. the whole magazine will pop out when it is freed.
Posted on Jul 29, 2010
SOURCE: I just received the Swingline
I can solve it!!!!!!!!! Remove the clear tape at the front of the stapler...the tape you cannot see, and push from the back of the stapler! Please note on the bottom of the box......it reminds you that this stapler does not come with paper or staples!!!
Posted on Apr 07, 2011
Rapesco 813-D stapler. What staples will fit?
try rexel for a replacement, they might do the job.
Aug 09, 2015 | Staples Tools & Hardware - Others
Rexel stapler
Sadly, the solution to this problem is very simply, and stated on the instructions for the stapler, which I ignored myself until I had bought my third one and continued to have the jamming problem. The solution is you HAVE to use the Optima staples they sell. Look for them in the silver metal box, and they are labeled Optima. Once I did that, all three of the staplers worked without a hitch, and I love them. Good luck!
Sep 30, 2013 | Swingline 48210 Optima ® 70 Electric...
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
Nov 05, 2012 | Tools & Hardware - Others
Has anyone found substitute rexel titan No 37 staples for the rexel titan tacker gun yet. The No 88 staples although they fit the gun do not fire as they are not fine enough .The original No37 ones are...
Rapesco Part number is: S14082M3. I've used these without problem
apparently Rapesco has now changed to Tacwise and they are now sold as
Tacwise 0346 (Type 140)
Oct 09, 2012 | Office Equipment & Supplies
My rexel stapler does not work, any help[
Sep 11, 2012 | Office Equipment & Supplies
How do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
May 04, 2012 | Tools & Hardware - Others
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
I have a rexel odyssey heavy duty stapler but the spring has popped out, how and where do I attach it back on?
Rexel Odyssey heavy duty stapler: The pring that pushes the staples into position can come losse if the stapler iss dropped. It's difficult to work out how to replace it! However, there are only two "lugs" that will take the circular ends of the spring. One obviously fits to the sliding staple retainer. The other to the back end of the pressed-metal inner body. However, to work, the spring must be threaded from this point along the pressed metal parallel-sided inner body back through a slot and over a rounded bent piece (shiny from prvious friction) and back down to the sliding staple retainer. It's trickey to do, but that's where it has to go in order to provide forward tension when the Stapler is closed.
Aug 02, 2011 | Office Equipment & Supplies
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
Hi Guys Rexel Cosmos 210 Stapler (Staple Gun - Mk II) I have a Rexel Cosmos 210 Stapler that has a broken white plastic bit. I have had it and used it at work for about 25 years. How can I get a...
I have one equally old and my plastic bit broke off many years ago.
I just get used to using it without.
It sticks but it's such a good stapler I forgive it.
Jun 12, 2010 | ACCO Brands Office Equipment & Supplies
63 people viewed this question
k24674
