Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
I have a kenmore hot water heater in the house that I just purchased. The model number is 153.336572. Over the past week I kept going downstairs and finding the pilot light out usually with a blinking error code. I reset it and it would work for a day or two. Today I went down to relight the pilot and there is no blinking red light indicating that it's working. I can light the pilot but as soon as I remove my hand from it, it goes out. Even in the off position there is supposed to be a red light that stays on continuously but there's nothing there anymore. I can't even find the correct replacement part online. Is there something I can do? I'm not sure if it takes a battery or if the whole thing needs to be replaced.
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Posted on May 01, 2017
SOURCE: pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Posted on Apr 08, 2009
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Posted on Oct 11, 2009
SOURCE: I have a gas hot water heater and the pilot won't stay lit
Typically, if you have replaced the thermocoupling and are still experiencing problems, it means the master control valve is bad. It also may be a venting problem, which I would not rule out. If you call the manufacturer with model and serial number, they will be able to help you better diagnose your problem.
Posted on Nov 19, 2009
SOURCE: pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Posted on Jan 23, 2010
Testimonial: "exactly what I wanted yo know. thank you"
SOURCE: We have the Rheemglas standard model #81V52DT-C
Hello, The cold water dip tube is busted.How old is the unit?A plumber can make a new one but might not be cost effective.
Posted on Apr 01, 2010
Jan 12, 2018 | Water Water Heaters
Mar 14, 2014 | Kenmore 50 gal. 6-Year Electric Water...
Oct 30, 2013 | Rheem Water Heaters
Dec 23, 2012 | Whirlpool Water Heaters
Jun 10, 2011 | White Rodgers Water Heaters
Feb 14, 2011 | General Electric Water Heaters
Dec 30, 2010 | Rheem ME85-18 Commercial Water Heater
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Dec 13, 2010 | RELIANCE ELECTRIC WATER HEATER
Feb 02, 2009 | Intermatic WH40 - Water Heater Time Switch...
Jan 14, 2009 | Water Heaters
130 people viewed this question
