Question about Bosch Nexxt 500 Dryer
Need to remove front panel on bosch nexxt premium dryer
  • 130 Answers
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Posted on Jan 24, 2009
SOURCE: Bosch Nexxt Electric dryer tumbling but not
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Posted on Apr 26, 2009
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
Posted on Jun 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
  • 3 Answers
SOURCE: Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Posted on Dec 01, 2009
We have a bosch front load stackable dryer that has coins stuck in the things that go around in the dryer, can we get them out?
You'll have to remove the top panel so you can loosen the baffles and get your coins out. Either that or take the back panel off and remove the drum altogether, which ever you find easier.
Jul 08, 2011 | Bosch Nexxt 500 Dryer
I n eed to find a scamatic for my washer
This video will show you how to change a door seal on this Bosch Nexxt Premium WFMC6400UC front loader washing machine
Jul 08, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I need owners manual for bosch nexxt premium washer and dryer
Unable to read the display. The letters are no longer readable.
Jun 21, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My dryer won't start. None of the buttons will light up when pushed. It is a Bosch Nexxt 100 series. It is plugged in and adjacent appliances (washer) work.
Remove the top panel and check for any wires that may have popped off from there connections!!
Do not forget to unplug the dryer from the power source for your safety!!
Oct 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Can i stack the Bosch front load washer with a kenmore elite front load dryer
There is no stack kit to do what you propose. That said, you may be able to construct a compartment on top of one unit to accept the other.
Aug 02, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch washing machine show E;04 plugged drain hose or pump
Remove cover to gain access to water pump, low rightside of front panel. Clean water pump. You should be good.
Jan 31, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
No LCD Display
they can fail try writing a letter to the manufacturer,if there a good company the will help.
Feb 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
530 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
