Question about MSI K8N Neo4-F Motherboard
No video msi 7125 ver 1
No beeps everything boots up still no video
5 Suggested Answers
  • 231 Answers
SOURCE: powered on MSI K7T Master Ver:1 motherboard and it beeps very frequently
Hi, it sounds like your RAM chips are not installed properly or are faulty, if you have 2 seperate sticks of RAM, remove them and install one at a time to test which one is at fault. make sure you use DIMM 1 for each RAM stick.
Regards mistyman
Posted on Nov 27, 2007
steve6375
  • 395 Answers
SOURCE: manual;msi km4m ver 1 notkm4m-l ver 1
http://global.msi.eu/index.php?func=searchresult&keywords=km4m&table=download
Posted on Nov 23, 2008
  • 13433 Answers
SOURCE: Msi 845 ultra Ver 1
The problem can be one of the following
1. incorrect bios settings: Unplug and remove bios 3volt memory battery, find CLearCmos jumper from the motherboard to reset the bios. - near the battery. I will check the user manual where it is and let you know.
2. Faulty or incorrect Ram memory installed. Try removing all ram memory from the computer, then turn the power on, it should complain by beeping or similar, turn off, reseat one memory module, then turn back on. If you get picture, the problem is solved. if you had more than one module turn off and reinsert it aswell, if the problem returns you most likely have a faulty ram, remove the module and start up with the ram module that worked. you may have to repeat removing all modules and then reinstall the one that worked to get image again.
3. faulty video adapter. Try another video card.
4. faulty cpu. If possible try another cpu or test this cpu on another motherboard.
Posted on Sep 25, 2010
  • 39 Answers
SOURCE: i have a msi k8n neo4 v2.0(ms 7125 ver:1). Was
Usually PCI just works like cable select; I doubt there are jumpers for it.It might be a busted motherboard.
Posted on Mar 04, 2011
2 short beep continue after 30second
AMI BIOS:
1 beep - System boot successfull
*1beep - Refresh failure - (NO VIDEO) memory refresh failure (bad memory)
2 beeps - Parity error - bad memory
As it is a Memory problem, the first thing to do is gently remove the memory chips (there maybe 2) and firmly re-insert them, to make sure there is a good contact.
If it still Beeps on re-Booting, then you need to go to a supplier to get them tested, or re-placed.
Source: http://forum-en.msi.com/
Author: Svet
Jan 22, 2014 | MSI FM2-A85XA-G43 Desktop Motherboard -...
I have just installed a 478 socket MSI MS-6526 ver 3 motherboard to my computer and all it dose is bleeps when i turn it on any help would be apricated
check for the error beep if you hear continues beep it means issue with the memory. check the RAM if it is properly inserted to the slots and if it is compatible to the motherboard. if you hear 2 or 3 beeps it means issue with the video. your video card maybe not compatible or not properly inserted to the slot. your motherboard has a built in VGA/Video card try using that first. try connecting the main components memory/RAM, power supply, KB and mouse, VGA card(optional you have a built-in) then check if there is a display or if it booted. then one by one add your other components you want to add. just to trace the problem.
May 19, 2011 | Intel Motherboard
Need a users manual for ms-7125
http://www.msi.com/service/download/manual-4370.html
Select US, or chinese if you'd like.
If this answer helped, please rate it appropriately.
May 04, 2011 | MSI K8N Neo4-F Motherboard
I need drivers fo pci for ms 7125 please send
Hello the download site is here:
http://www.msi.com/service/search/?kw=ms%20%207125&type=product
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#/?div=Driver&os=All
If the driver not fit select another MB.
First select your windows system.
The drivers you may download needs to be unziped
before you install.
Good luck
Jan 02, 2011 | MSI : 7125-040 (K8N NEO4-F) Socket...
Trying to find manual for ms-6330 ver 2:1
Manuals are present on the MSI Web Site: http://www.msi.com/index.php?func=searchresult&keywords=ms-6330
May need to Fish Around a bit... not sure which one is yours... didnt see a ver 2.1. May be able to match the Pic or Boot the MB to see the details.
Dec 31, 2009 | MSI MS-6330 Motherboard
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
Powered on MSI K7T Master Ver:1 motherboard and it beeps very frequently
Regards mistyman
Nov 26, 2007 | MSI K7T Master-S Motherboard
MSI K8N Neo4-F Motherboard Logo
23 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
