Question about Intel Computers & Internet
SA86510A.86A.1024.2006.0504.1017 update BIOS updation
4 Suggested Answers
  • 231 Answers
SOURCE: ASROCK 845 BIOS PROBLEM
Hi, This problem sounds more like a failing poewr supply than a bios problem. Can you use a multimeter? If so then check the voltage output from your power supply. The red wire = 6v+or-1v. The yellow wire= 12v+or- 1v. black is negative. If you are not sure then try a different power supply. Goodluck mistyman
Posted on Sep 15, 2007
vancer32
  • 31 Answers
SOURCE: BIOS settings to boot from bootable USB Key
try different USB ports
Posted on Jun 09, 2008
SOURCE: Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Posted on Apr 01, 2009
Actualizacion de BIOS SA86510A.86A.1024.2006.0504
The BIOS number corresponds to Intel Desktop Board D865GSA. You can find the BIOS at following link
https://downloadcenter.intel.com/download/10671/BIOS-Update-SA86510A-86A-
It was released in 2006. The latest BIOS is at following link and it was released in 2010.
https://downloadcenter.intel.com/download/12687/BIOS-Update-SA86510A-86A-
Aug 10, 2015 | Computers & Internet
I want latest BIOS drivers for INTEL DH55TC desktop board. I've gone to http://downloadcenter.intel.com but the latest BIOS drivers available in INTEL site is TCIBX10H.86A.0048.EB.EXE & Date:1
Those are the latest drivers you can get. Bios updates aren't created on any regular schedule or anything, and eventually they stop updating them altogether when the board is past its manufactured life cycle. They may make another update in the future, but then again they may not.
If you are having an issue with the motherboard that's not been addressed/fixed by the last update, then the only thing you can really do is email Intel and tell them about it. If they get enough complaints about what your issue is, then the probability they will fix your issue and make a newer Bios update will go up. Luckily Intel has more resources/programmers than most other companies in the business and thus your chance of getting a Bios update is better than average.
May 20, 2012 | Intel DH55TC Motherboard
Cannot detect onboard sound plz help me
did you updated the correct firmware for your bios, sometimes faulty updates lead to this post me *********** board model and make
Feb 27, 2012 | Intel D101GGC Motherboard
Bios settings changed automatically
Have you tried to update the bios? One of the latest versions BIOS Update [DPP3510J.86A] 07/15/09. But verify to ensure that you download the correct bios for your board. There are a few options available. Also check the jumper pins for the bios on the motherboard normal or (default) setting is pins 1-2 jumped.
Nov 10, 2009 | Computers & Internet
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Computers & Internet Logo
93 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
