Question about Aluratek 12-inch Hi-Res Digital Photo Frame - ADMPF312F
Vlc media file won't work in aluratek frame
Admpf315F
Why can't my pandigital picture frame play my movie all the way through?
Does this happen with all movies or with one particular movie?
It could be that the movie file is broken or incomplete.
You could test the file on a different computer, but bear in mind that some movie players can be more indulgent with problematic movie files than others.
Personally I have several movies that play excellent with the well-known VLC Media Player, but will consistently fail using other media player software.
I hope this helps.
May 17, 2014 | Photography
Tip
How to convert your video file formats using VLC media player?
Are you tired of converting your video file formats,wasting time on it.
do you know VLC media player can used as video converter.the good thing is it convert videos of 1gb size within 1min.follow steps below
  • go to file or media menu->convert/save(ctrl+r)
  • add you video file
  • click ->convert/save
  • new dialog box will appear
  • set your parameters (i.e) frame size,video and audio bitrates,output format,destination folder(save your file name output file format extension)
  • click on start button
on Jun 13, 2010 | Computers & Internet
Not able to play .mkv files. Please provide with the solution. I had also installed the K-lite Codec. Using XP operating System.
Download VLC media player or DivX. I use VLC media player as my media and audio player. It is the best free program out there. DivX can also play .mkv files.
VLC Download
Divx Download
-G33k
Jul 27, 2011 | Intel D845GVSR Motherboard
I was trying to view a file that i haven't completed downloaded yet with vlc media player. while building font cache vlc media player is mixing up two different video files of same name and playing them at...
There is no problem with VLC. You must be downloading a torrent and the file is partially downloaded in parts and hence VLC mixes videos. It happened to me too.. Dont Worry. Once the download is totally complete, VLC will play the complete file.
Regarding font cache it happens only the VLC is installed and launched.
Apr 05, 2011 | VideoLAN VLC
VLC Media player is the one I am using, Is this VLC have codec already?
vlc should come loaded with all codecs available for the player.it even plays downloaded youtube format type files if im not mistaken. goodluck
Mar 11, 2011 | Computers & Internet
CANNOT PLAY 3GP FILES
There are several ways to play 3GP files. My personal favorite is VLC Media player (or if you prefer using Windows Media player, pls refer to 2)
  1. VLC ( http://www.videolan.org/vlc/) media player (freeware) is presented as the easiest solution to playing back many of the common multimedia files that are available. However, while VLC does in fact support the 3GP format, it does not include software to decode AMR audio. If your files have AAC audio then technically, VLC should be able to play your 3GP files.
  2. Windows Media Player can technically play 3GP files, but you will need to install some extra software. Firstly, the 3GP container needs to be accessible and then you also need software that can decode the video and audio (H.263, H.264, AAC, AMR). You can use either
Aug 07, 2010 | Computers & Internet
Unable to play video clips or avi file on media player 11
You need to play these files on VLC or in Media Player Classic. You can play almost any media file through them.
If you don't have any then you can download VLC media player from the following links:
for windows os zip file 16mb: http://videolan.cdn.cacheboy.net/vlc/0.9.9/win32/vlc-0.9.9-win32.exe
windows 26mb:http://www.gtlib.gatech.edu/pub/videolan/vlc/0.9.9/win32/vlc-0.9.9-win32.zip
& for mac 19mb: http://mirror.leaseweb.com/pub/software/videolan/vlc/0.9.9a/macosx/vlc-0.9.9a-intel.dmg
And if you want media player classic here is a link to download it: http://mirror01.x264.nl/x264/mpc2kxp6490.zip (212mb)
If these players cant play your files then might not have given enough time to download your torrent or must have downloaded corrupt file.
Apr 14, 2009 | Microsoft Windows Media Player
Window explorer stop working
hi,
Try VLC Player for your .vob files instead of just opening is.
Install VLC Player and and from VLC players file menu try to open the file.. It will work perfectly.
Regards
Jan 22, 2009 | Compaq Presario 700 470024-192 Notebook
Wanna change my defalt media player
Well M8, fist of all, mediaplayer plays avi-files:) you just need to uppdate the codes on it.
But if you want VLC to play all your files, i like VLC to, that easy done.
select an avi file, rightclick on it, select OPEN WHIT, select VLC and mark the little square that asks if you want the all similar files should be open with VLC.
Then do the same on every other media format you want your to start in VLC, not all the files, just one of each format. Dnt forget to mark the square in every one you change.
Good luck to you!
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Aluratek 12-inch Hi-Res Digital Photo Frame - ADMPF312F Logo
24 people viewed this question
Top Aluratek Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you an Aluratek Photography Expert? Answer questions, earn points and help others
