Question about Sony MHC-GX25 CD Shelf System
Disc changers do not work
Changers do not work properly
My 3 disc change not working properly. cd are d2 and d3 and will not ejeck
Loosen 4 screws on bottom. You may want to take the two front ones out. They are phillips head. Drop the botom portion of the changer down about an inch or so. You will see all the disc that are stuck. Take a pair of micro plyers and simply grab the edge of the disc and gently pull and it will come out very easily Be sure and grab the very edge of the disk so as not to damage it. It took me all of 5 minutes to remove the disc in a 3 disc changer. What caused it to become stuck in first place is another question. You shoud have a green light beside each slot that has a disc in it.
Sep 24, 2016 | Bose Wave music system Multi-CD Changer...
My panasonic sa-vk72d disc changer wont work.. The system hangs because the disc changer wont work properly
CD loader mechanism fault. Contact any service technician. This repair can't be done by a normal user. Gopakumar Gopalan Google
May 08, 2014 | Audio Players & Recorders
Hi I have put a cd into the changer but now cannot eject the cd, the stereo reads error 99 please advise
The CD, when inserted, became either wedged or not seated properly and the sensors dont know how to respond. Here are the codes for Kenwood.
Changer Error Codes
• E-00: Poor Cable connection.
• E-01: Magazine not properly set in changer.
• E-02: No Disc in magazine.
• E-03: CD does not have selected track number.
• E-04: Disc is dirty, upside down or unreadable.
• E-10: No data is recorded on the MD. The player plays the next disc automatically.
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
If you have a steady hand... carfully unscrew and open up the unit just far enough so you can either pull, or nudge the CD tray enough for the CD to be seated in the tray properly...
Good luck...
Nov 20, 2012 | Televison & Video
Player will not change disc Remote controller shows 4 dashes where it will indicate the disc that is playing and what #
It is possible that the unit was hit by a small power surge and if you leave it unplug from the wall, for 40Min., it should clear the processor of any garbage that could be in it, and reset back to normal.
Jun 13, 2011 | Panasonic CX-DP801 8-Disc CD Changer
Discplayerwontplay open or rotate
You will need to take off the surround metal and look down into the disc changer. There are gears mixed with small belt drives that are used to open and rotate the disc changer. If the teeth of the gear or the rubberbands are snapped this will cause the player to not work properly.
Please accept if this helpful.
Thank you
Mar 03, 2011 | Kenwood CD-203 5-Disc CD Changer
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
CD changer eject button does not work. Three discs are inside. Changer works. Good sound is produced. But unable to eject disc changer to change discs.
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Oct 27, 2008 | Curtis RCD-897 CD Shelf System
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Nov 17, 2007 | Clarion DC625 6-Disc CD Changer
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
Sony MHC-GX25 CD Shelf System Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
